Question about Kenmore 76129 Air Conditioner
Kenmore the biggest 110 unit you can get, keeps shutting off
My Kenmore 110 unit will be on working just fine and just SHUT OFF!! by itself. Sometimes I can cut it back on and it stays on and sometimes it stays on for a minute or two shut off and come back on by itself. ITS POSSESSED
  • 378 Answers
There is something wrong with your switches maybe. Or the thermostat problem occur.
Posted on Jun 01, 2009
I have a Kenmore elite HE3T front load. It gets down to 6 min then stops and flashes between 06 and F, what can i do?
Kenmore 110 4996 Use And Care Manual Troubleshooting
  1. "F" Variables [other than FH and F02] (=Electrical Problem)
  2. Select STOP twice to cancel the cycle.
  3. Select DRAIN & SPIN if there is excessive water in the washer.
  4. Unplug the machine for thirty seconds to reset the Central Control Unit
  5. Re-select cycle and press START.
Feb 27, 2015 | Kenmore Elite 45986 Front Load Washer
Kenmore 110 washer fills and does the wash cycle but wont drain or spin. Totally shuts down after wash cycle. What do I need to replace
sounds as though the lid switch has gone bad, either that or the motor has lost the reverse winding on it.. most likely lid switch tho.
the lid switch is only "seen" by some older kenmore "110" series at the end of the wash cycle, or end of the rinse cycle. it purpose is to keep the unit from spinning if the lid is opened so no one looses an arm, etc.
generally the console on those machines hinges over backward so you can remove the cabinet top and 3 sides as a unit together..
the lid switch is under the machine top and isn't easily accessible without removing the cabinet.
May 20, 2010 | Washing Machines
Freezer won't stay shut
If you want a part number for the replacement door gasket please provide a complete model number here so I can give that to you or you can look it up yourself at www.searsdirect.com You must have your model number. (sample 110.XXXXX etc)
The magnet is inside the door seal itself. If the seal is damaged replacement is your only option.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Refrigerators
Kenmore stove oven does not shut off
Wow, this post is going to be extremely late. Actually, I was able to get a new control unit for my Kenmore gas range from Sears Parts Dirext for $156.06. That includes shipping and tax. The burners work without it. We just cannot use the oven until the new board comes in. It's very easy to replace. Remove the panel screws on the back (just the top) and you have access to unplug the unit and remove the 4 screws holding the assembly in.
Jun 05, 2009 | Kenmore Ovens
FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
Feb 09, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore side by side md#253.4430303401
maybe compresser hi- limit on the compreser.
Dec 09, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore Elite drying doesn't work sometimes..
Touch pad is failing.Try not to get any moisture around this touch pad.Biggest mistake for all appliances is the touch pad and water dont mix well.
May 21, 2008 | Kenmore Dryers
Kenmore Progressive Canister w/Hepa Filter
May have a problem with the motor protector or the motor itself. The motor thermo protector will shut the motor off if it senses it getting hot. So it could be bad.
Apr 13, 2008 | Kenmore 22313 Bagged Canister Vacuum
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 76129 Air Conditioner Logo
268 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
