Question about Honeywell Programmable Thermostat Heater
T8411r1028 honeywell thermostat blank screen where would fuse be?
No pwer blank screen I also have a Honeywell T8411R1028 with a blank screen. Where would the fuse be located?
    Problem Solver:
  • 9 Answers
That thermostat should get power from 24V side of a transformer in the air handler. There should be a fuse in there on the PCB, but just as likely, there may be a 2-wire sensor in your drain trap that will shut it down if it senses water backing up in the drain piping. Clear that line from the outside of your house with a shop vac, cycle the breaker for the air handler if needed. You may also be low on freon, though, so a service call might be a good idea anyway.
Posted on Oct 06, 2009
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
Honeywell thermostat short and then went blank by mistake i short the thermostat with a wire and then became blank
Check the transformer in the air conditioner/heater. There should be a fuse on teh 24 volt side. Shut power off to the furnace. Locate and check the fuse. If there is no fuse, you probably destroyed the transformer.
Jul 17, 2010 | Honeywell Programmable Thermostat Heater
The thermostat worked correctly for months then
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need
May 10, 2010 | Honeywell Programmable Thermostat Heater
I get no power on my 8411t honeywell just blank.
Fuse in heating system, bad transformer or maybe a bad connection in the wiring.
Jan 16, 2010 | Honeywell Electronic Programmable...
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
Check in the heating unit itself for an automotive style fuse.
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
2,576 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
