Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Scan to email over ssl
Ricoh MP 2000 will no longer scan to email when the host was switched togo daddy which uses SSL.. How can the ricoh device scan through SSL??
  • 1 more comment
  • Anonymous Mar 17, 2014
    scan to email Ricoh MP2352SP
    will not scan
    port server not scan
  • 183 Answers
Ricoh dose not work through SLL
Posted on Jul 16, 2009
  • 114 Answers
Ricoh does not support SSL and no known work around as of yet
Posted on Mar 19, 2010
    New Friend:
  • 10 Answers
When you scan to e-mail you need a smtp server.
Posted on Jun 11, 2009
I used to be able to scan a lot of documents and then just last week I couldn't scan any document using the Ricoh Aficio Type 2018. The message "Sending has failed. Press Job Information key to check the...
It is a problem with the network connection, if you are using scan router recheck the configuration settings in case of scan to email check connection with smtp server, port no. ssl on or off and do the connection test, check mail server authentication, rest assured it is not a problem with the machine or GW controller.
Feb 18, 2015 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh MP C5000 can't scan to gmail
once again the tech boyz mix up the formula ssl is a device unique identifier technology which has many permutations i'd expect it will take an act of God to get gmail apps to do this for a single device, and Ricoh is not in that business
keep an eye on the gmail apps forums and you might get lucky
May 29, 2012 | Ricoh Aficio MP-C5000
Ricoh 1232c scan to email SSL issue
no work around for machine. you can scan to a folder on the network, than attach your doc to an email. only way to do it on a ssl.
Mar 24, 2010 | Ricoh Aficio 1232C Color Copier
How can scan and put or transfer it in my yahoomail
I believe yahoo uses SSL and Ricoh dont support it so the only way is ti scan to folder then send to yahoomail
Mar 23, 2010 | Ricoh Aficio 2020D Copier
My mp 2000 ricoh scanner and printer only works for printing, not for scanning
if you have not set it up to scan you need to do so. go to ricoh.com then americas then knowledge base then white papers. and look for how to set up scanning to email or to folder.
Jan 13, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Changed email hosting, now scan to email does not work
I'm confused. Are you saying that the programmed addresses don't work, but if you manually enter an address you can send?
Was your Gmail ( or another Gmail) account formerly the account to which the machine's settings were associated?
In order to use the scan to email, whatever settings have changed in your main email account, for example: username, password, SMTP & POP servers, etc, must be changed to match.
I am prettty sure you may have some difficulty, however if your new host uses Email encryption (SSL) , because I don't think that machine is compatible, so you may have to (somehow) configure an extra email account within your Outlook, or whatever you use that does not require authentication.
Feb 23, 2009 | Ricoh Aficio 2015 Copier
Richo 5510nf isn't sending the faxes to the pop server
First, disconnect the fax from the wall and any other device ( after powering down), let set about 30 sec to 1 min. and then only plug the power and phone line into device and power up. Try a hook ( like you are making a call) call to a known fax number, listen for the communication tones -- if they are there, hang up and try to send a fax to that same number. If the error continues you have a scanning problem with the device.
Dec 31, 2008 | Ricoh FAX5510NF Plain Paper Laser
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
1,943 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
