Question about Garmin Nuvi 350 Car GPS Receiver
At first my GPS would come on but not stay on. Now it will not come on at all.
  • jhilton14 Jun 01, 2009
    I have a C340, not a 350. Does that make a difference? I will try your suggestion about plugging it into another cigarette lighter. If the plug is defective, can I find a new one? Thanks.
  • jhilton14 Jun 06, 2009
    The battery was completely run down. I attached the unit to a trickle charge from my computer overnight and it works perfectly now. i can't explain why it wouldn't accept a charge from the car battery.
  • 4,472 Answers
First off how long have you owned the unit? If the unit is under warranty have it serviced that way if not. I would recommend having the unit serviced. If you need further assistance in getting the contact info for company or independent service center please let me know. Thank you,
Lee
Posted on Jun 06, 2009
  • 1,040 Answers
I think you should check the fuse for that particular plug-in. You could have blown the fuse.
Jim
Posted on Jun 02, 2009
  • Jim Parker
    Jim Parker Jun 06, 2009
    Did you solve the problem? Was it the fuse?
    Jim
  • Jim Parker
    Jim Parker Jun 17, 2009
    Thanks for the rating. I hope you got your problem resolved.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
    Brigadier General:
  • 3,917 Answers
Would you be able to try a different charger. Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?). Try this, start your engine and then plug in the nuvi car adapter. The nuvi should turn on by itself. If the nuvi doesn't turn on either the adapter is defective or the cigarette lighter is no supplying power. Try the same test on another car if it works then I would say that the cigarette lighter power supply on the first car is defective, but if it doesn't then I would say that the nuvi adapter is defective. BTW there is a fuse inside the nuvi power adapter which might have blown.
Do you have one external GPS antena, i know that you have integrated antena in Nuvi but there is also options for one external so that may solve your problem.Also try to set up a routing speed for gps in your setings for your model routing speed is 14.97
You can go here and read this and download it: http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf
Thank You
Posted on Jun 01, 2009
Odometer stays on after key has been turned off
Did u do any additions to your electrical ie gps or anything that had an internal battery? I have seen some ppl add things and tap into existing wires. Basically when you shut off your ignition key, your gps stays on and back feeds power to your bike until the battery in gps dies. Either change where you hooked up or add a diode.
Jul 29, 2012 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Battery won't charge, screen wont stay on
Check the fuse in the power cord, if it is good then it might be the battery in the gps unit has gone bad. If it has then you will most likely never get the unit to stay on until you change the battery out. Bad battery no gps, no idea why just the way they are designed. Hope this helps
Jun 01, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
The unite only stays on for about 15 min and then
Did you check the setting, it maybe on power saver mode?
Apr 13, 2010 | Garmin Golf Logix GPS
I HAVE PLUGGED THE GPS INTO MY COMPUTER. GPS
You're doing everything correct. When connected to computer GPS stays on front page. You'll need a program called TomTom Home on your computer to manage your GPS device.
Apr 01, 2010 | Tomtom One XL GPS Receiver
Navigon 5100 GPS Navigator - Will Not Turn On
my tomtom Go 720 stays frozen. When I try to push the "I agree" button it stays frozen.
Mar 28, 2010 | Navigon 5100 GPS Navigator Handheld GPS...
Tomtom930 wont stay charged..cahnged the battery
it sounds like your power adapter isn't supplying enough power to the unit. You should be able to try switching out the adapter with another and see if that helps. If the doesn't help, then there may be a problem with the recharging circuit on your GPS. AT which point you should contact TomTom.
Feb 22, 2010 | Tomtom GO 930 GPS Receiver
Not able to acquire satellite. Garmin stays on
The flip-up internal antenna/GPS receiver is defective and needs repaired/replaced. Please see this link fo rmore info:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Sep 15, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 200W GPS power supply will not stay plugged in
hpd367 - If your Garmin has died within a year then call them for an RMA number and they will repair/replace it.
Tel 0808 238 0000
Moscow Nell - I had the same problem and got an adaptor from Halfords for about £5.
Mar 27, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
46 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
