Question about Microsoft Xbox 360 Console
Xbox 360 nothing displayed on the screen
When i turn my Xbox 360 on i goet noting on the screen, the console itself appears to be working perfectly, i can hear the fans working inside and there are no red rings... i have already tried using it on a different TV and using a different scart lead, i have also treied using the HD cables. The Xbox 360 i am using is the older version before they added a hdmi port, any help/ advide would be much apreaciated
  • Liam Bower Jun 01, 2009
    I have checked this, and i have tried it with a HD TV, im thinking it might be somthing to do with the connections to the port inside the console itslef if that makes sense?
  • 57 Answers
First make sure the switch on your cable is on "tv" not "high def"
Posted on Jun 01, 2009
There is no solution you have to turn your xbox in to get it repaired
Posted on Jun 16, 2009
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
Tip
How to set up WiFi on XBOX
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
Save your settings and verify the network is functional.
On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
on Feb 07, 2010 | Video Game Consoles & Games
The screen is enlarged after watching a movie how do we fix it?
Hi melissami133
PLEASE RATE MY ANSWER IF ITS HELPFUL !
FOR XBOX:
With the new Xbox 360 interface, the how-to below is not working anymore! You can do the following to reset your console:
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
  • 1. Remove any discs from the disc tray.
  • 2. Turn the console off.
  • 3. Turn the console on.
  • Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller.
    Note Make sure that you use the player 1 controller when you do this. The player 1 controller is the controller where the upper-left quadrant light is on.
  • 4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console. So it's OK when the Xbox 360 console restarts.
FOR PS3 :
Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Jan 30, 2011 | Video Game Consoles & Games
When the xbox is switched on a black fuzzy screen appears, we have tried different wires that work with other xboxes and it still does not work. We have also used our wires on other peoples xboxes which...
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Feb 23, 2010 | Microsoft Xbox 360 Console
How to hookup wireless internet
The console is on as is the controller, but nothing is appearing on the tv screen? I have checked all the leads and everything appears to be conncected ok?
This can be because the scaler chip that deals with the display has overheated to fix it you will need to send it in or use a good Xbox 360 repair guide to fix it
Nov 16, 2009 | Microsoft Xbox 360 Console
Xbox 360: colour/display failure
most likley a cable issue if you are using hdmi make sure its fully homed in same with the others but have you checked the display settings on your xbox? otherwise borrow another cable just to find out
Aug 06, 2009 | Microsoft Xbox 360 Console
Screen won't show up but this is diffrent
This happened to mine and it had to be sent back to be repaired (3rd time) as the graphics card had failed; it started with the display colours looking strange, then the picture went totally. If you can hear everything working (beeping/whooshing" as you go through the "blades", it sounds like you have the same problem. below is how to reset to the default display sttings just in case anything has gone wrong on this.
To reset the display settings of the Xbox 360 console to the default settings, follow these steps: (Copy and pasted from Microsoft support pages)
If this doesn't work then try phoning XBOX Support on 0800 587 1102.
Dec 23, 2008 | Microsoft Xbox 360 Console
Broke
1.Remove any discs from the disc tray.
2.Turn the console off.
3.Turn the console on.
Aug 09, 2008 | Microsoft Xbox 360 Console
Xbox 360 turns on, but nothing shows on the screen
If the person that you bought it from on E-Bay had an HD Television. Then the Xbox console is set into HD from the Display options. If your TV is not HD, then It will not display. It can also be the other way around, if His TV is standard and yours is HD. Also try looking at the RCA's(The Part that plugs into the 360) And you will see a slider. Switch the slider, then turn it on. Tell me if that works, if Not, tell me and I will tell you what to press on your 360 controller to set the other menu. Hope this helps.
Jul 11, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
226 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
