Question about Acer Aspire 5500 5570-2609 Laptop
Laptop does not turn on.
My Acer laptop does not turn on. when connected to power supply - light on power converter on the power cord starts blinking. If laptop is unplugged, light on power converter glow steadyly. thanks for ur help.
  • 400 Answers
It is the problem of you power cable pluged into the laptop from adapter which does not supply the steady current to your laptop the it causes the disconnectivty
Posted on Jun 01, 2009
  • 674 Answers
Chech the power button or power switch button...
then som part of board..
thanks
My acer aspire notebook 7736Z-4412 won't turn on. I have tried taking out the battery and using the adapter but it still won't turn on?
yes boss pl remove ur battery n start only ac supply if ur laptop on or not if run ur battery defective or not run at ac ur laptop ac supply ac to dc converter circuit problem pl send my address solved n send u
May 26, 2014 | Acer Aspire One PC Notebook
My acer aspire starts up to the microsoft logo then turns off. i think the battery is dead because when i take out the power cord the battery light goes out. but should it still start with the charger...
Hi
If your battery is dead you can still use your laptop with the power cord connected and turned on
have you tried charging your battery for a couple of hours with out using the laptop just to see if the battery will charge and hold its charge for a while
many thaks
Jun 23, 2011 | Acer Aspire 5735 Notebook
Laptop do not turn on
Try removing the battery and starting in with only the power cord. You need to supply a little more info to get better answers.
Jul 14, 2010 | Acer Aspire 4520-5582 Notebook
Acer Notebook won't start up. At first we thought the powercord was damaged because the green light on it would blink. We got a new cord but the light just turns off and the computer won't start.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 23, 2009 | Acer Aspire 4720 Notebook
Acer aspire 5552nwxmi notebook can't power on.
Unplug the battery and power supply from the laptop, then press and hold the power button for 25sec(No battert and power supply), then connect the cable back to laptop, then try to turn on the computer, if its turning on hten connect battery back to laptop...
Nov 24, 2009 | Acer Computers & Internet
I have an acer aspire 5570z and it wont power on, at all the. battery is fine and the charger is fine i have tested both any help is much appreciated
Hello there:
This could be the result of a couple of different things
The power connector where you plug your power into the computer could have a piece that is broken in there
or you could have a bad power converter on the board it'self that could be bad
and you might even have a bad power supply in the computer
First i would remove the power cord and battery and press in the power key to discharge anyesd that may be stored and hold it in for 10 to 20 seconds andthen connect the power cord and see if any lights come on
showing that you are getting power if not i would start troubleshooting the connector piece for the power cord but if their is power showing now try to start the computer if all is good than you should be able to turn it off again and reinstall the battery and try it again but if still nothing than you will have to troubleshoot the motherboard or the power suply ok If you have a warranty on this you may consider using it
I hope that this is very helpful for you
best regards Michael
Nov 18, 2009 | Acer Aspire 5500 5570-2609 Laptop
My ACER 5570z will not start up. When power cord
You most likely have a broken DC Jack on the motherboard. Thus, the battery cannot get a charge and the power supply is not making a connection to the system board because of the broken DC Jack.
Good Luck
Sep 29, 2009 | Acer Aspire 5500 5570-2609 Laptop
Hi Hoping some one can help me I have an acer
U ARE HAVING PROBLEM WITH UR POWER CORD OR YOUR BATTERY
Jul 15, 2009 | Acer Aspire 4520-5582 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
373 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
