Question about Kenmore Elite 45986 Front Load Washer
Water that seeps into washer after cycle is done
I have water that will seep in after a cycle is done or even if its empty. I have to hit the drain and spin cycle to get rid of the water but will look a couple hours later and the water is back.
    President:
  • 1,136 Answers
Hi, If you are getting water in the tub when the washer is off, you will need a new inlet mixer valve. You can test this by tirning the water off at the wall and see if any water seeps in. If you would get me a model #, Icould look this up for you.
Please let me know if I can assist you further.
Vic
Posted on Jun 01, 2009
I have an electrolux EIFLW55HIWO washer. When I wash clothes everything is okay. After emptying the washer it will let water seep back in. I will do the spin cycle and a couple days later the washer has...
Hello friend, thanks for your inquiry!
I see you are experiencing a water issue within your Electrolux washer. It sounds like it could be a problem with your water valve, drain pump, or control board. Since it could be any one of these underlying issues I would recommend having a professional come and diagnose your appliance properly. I hope this helps to some degree. -Matt
Aug 23, 2014 | Electrolux Washing Machines
Water slowly runs in washer when it isn't on
Sounds like a valve isn't closing properly. I would suggest you call for service.
Oct 24, 2017 | Whirlpool Duet GHW9150P Front Load Washer
My front loader LG washer works fine during the load, but when I come a while after the load is done, water has seeped back into the washer and I have run the drain cycle to get it out. LG says it needs...
If you have the capability its probably a leaking seal on the water input line at thetop of the water. Often its a simple hoseclamp that needs tightening. Without looking myself thats the easiest solution. Hope this helps!
May 09, 2011 | LG WM-2277HW Front Load Washer
My washer won't drain near end of cycle. Motor
The problem will be on the main board or the power supply board of the machine might have some problem kindly the check the wire lines as well
i do not think that drain pump is having any problem
Dec 30, 2009 | Kenmore 42822 Front Load Washer
Water seeping back in washer after load is done?
Very possible your household drain pipe is almost the same size as the washers drain pipe. The house hold pipe should be approximately twice the diameter so as to allow equalising air in while water is being expelled from the washer. If at any time there is water flowback, it wont be forced into the washer pipe as it will now have an air gap.
Oct 06, 2009 | Kenmore 43142 Front Load Washer
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Kenmore 22422 seeping water from under machine
look underneath the washer.there sould be a hose there.sometimes an unbalanced load can cause the hose to rub up against sharp metal when the machine vibrates.mine had a zip tie that held the hose to close to the edge of the machine which had some sharp metal and it put a small hole in the hose.hope this helps.
Dec 19, 2008 | Kenmore 22422 Top Load Washer
GE Front Load washer problem
replace the water inlet valve it is seeping water through the valve even though the cycle has finished
Apr 28, 2008 | GE WSXH208A Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
115 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
