Question about GE WSXH208A Front Load Washer
Should glasses and dishes be rinsed before putting them in dishwasher
Should glasses be rinsed before putting them in dishwasher?
  • 686 Answers
No need to do that
Posted on Jun 01, 2009
Cycle wash leaves marks on glasses
Is the rinse aid dispenser full? Then, you might need a better brand of rinse aid or detergent. Some lead crystal glasses can't be put in a dish washer but you have probably considered that.
Sep 06, 2015 | Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
My dishes come out dirtier looking after washing in the machine.
check the water temperature is reach the desired setting,clean the rinse arm and check the rinse soaf if working at end of wash cycle.
Jun 05, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Not rinsing glasses clean
If the glasses are spotty from hard water try a rinse aid like Jet Dry. If they are actually dirty, depending on the brand of DW you may need to rinse them better before putting them in the DW. Not all brands are cerated equally, some do work better then others
Oct 11, 2009 | Dishwashers
Dishes never come out clean
Sounds like not getting sufficient water. Replace water valve if that's the case.
Nov 14, 2017 | Whirlpool 24 in. Built-In Dishwasher w/...
After my dishwashing cycle is complete there is a residue left on the dishes -- I only fill the soap half way and i use a rinse agent.....
Dishwashers work best when the following "rules" are followed.
1. Rinse food off of the dishes before you place them in the dishwasher.
2. Face plates toward the center and do not over crowd them.
3. Always put glasses on the top shelf and always put plates on the bottom.
4. Run the hot water in the sink until it is as hot as it will get before you start the dishwasher.
5. If your dishwasher has a pot scrubber cycle use it and it will make a difference.
Doing these things should solve your problem. If not, let me know.
Jan 04, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
Food on dishes
Dish washers are not good at removing food debris.  They filter the water somewhat but in the main, they recirculate whatever was on the plates when you put them in plus the detergent.  The rinse takes all grease and solubles away.  Scrape your dishes of as much as you can before putting them in.  Use a good detergent in the amount specified.
Nov 26, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
GE WSXH208A Front Load Washer Logo
44 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
