Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Fan started running backwards
I have a portable air compressor and when I was using it, it all of a sudden quit pumping air and the motor still ran. I took off the vent cover and noticed the Fan Blades are turning backwards. It is sucking air instead of blowing air now. I disconnected the air lines and blew air through them and there were no obstructions. I cover the holes to draw air and the fans started to turn in the right direction, but quit and went in reverse again. What is causing this air compressor to make the fan blades go in reverse?
It is an older air compressor and I believe it's an Ingersol Rand with a 2-3 gallon tank
    Problem Solver:
  • 9 Answers
Worn check valve/diaphragm
Posted on Jun 05, 2009
The a/c on my 2010 Mercury Milan quits blowing after about 2 hours of driving. Any ideas?
Sounds to me like the A/C clutch is no good and out of adjustment.You should goto your nerrest junkyard and get a used assembly take the clutch off then you learn how it comes off and install it on yours the save the pump for later use if needed. The clutch should only have a .010 air gap after install between th inner elctro magnet and the clutch plate it's self.
Aug 04, 2012 | 2010 Mercury Milan
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
The fan in the compressor for the HVAC unit quit running last night this morning after 2 attempts it started and ran fine , cooled form 76 to 72 in about 45 minutes, but when I tried to start it again the...
Replace the fan motor and capacitor. If you want to go the cheaper route, change the capacitor first and try to run the unit. The cap. is what gets the fan motor running on start up. Another way to test it is to manually turn the fan bade and while it's still turning, make sure your hands are clear of the blades and turn the condensor on. If the fan runs normally, then it's your fan capacitor.
Jul 02, 2011 | Amana Heating & Cooling
I have a makita MAC2400 2.5 HP that suddenly stoped It's almost brand new but does get plenty use, the oil level was very low or may have just ran out. I added more oil but will not come on, what is the...
Hi and welcome to FixYa, I am Kelly
Remove the rear cover Item 33 this link:
http://www.ereplacementparts.com/makita-mac2400-25hp-1720rpm-air-compressor-parts-c-97_1547_7559.html
Gently start rocking the fan GENTLY back and forth by gripping it in the large center area and see if it will rotate. If you ran it completely out of oil; the piston, piston rings or rod end bearings will seize up. If you can not rotate it by hand and your sure it has locked up... you are going to have to overhaul the pump or replace it. The link above is a good source for parts.
Before considering an overhaul... read out the motor windings after the pressure switch to see if the motor windings are open or read a resitance value under 480 Ohms.
Depending on the motor pump used most of them have thermal overloads that will self reset when the unit cools off. It should self reset in less than 15 minutes if there is one. Ones without a thermal overload end up cooking the motor windings or tripping the house circuit CB if they run out of oil.
Thanks for choosing FixYa,
Kelly
Mar 31, 2011 | Makita MAC5200 Electric Powered Air...
Fan motor runs backwards
Make sure the capacitor is connected to the start lead, not the run lead(s). Also some fans come with some wires you can switch to reverse the direction. If your motor has them there will be 4 and the label on the motor will tell you how to connect them. Let me know if you need more assistance or if this helps.
Jun 02, 2010 | Carrier 38CKC042 Air Conditioner
My unit has been running great up till now. Just
Check compressor for high current consumption.Check capacitors. Check fan speed.
If fan speed is low compressor will over heat and trip safety circuit in the compressor. If there are independent fans check both of them.
May 26, 2010 | Mitsubishi MS-A12WA Air Conditioner
Pump humms and barely turns. Fan blade caught wire caused huge spark. wire has been replaced.pump does not really seem to get going and trips safety after a minute of running.
hi there!
short circuited at start damage motor compressor
if you have a service center for motor compressor have checked this one, motor compressor has thermal overload protection mostly on single phase motor inside the motor,in the absence of overload protector the winding of motor on start and running maybe shor circuited.this should be rewind by motor rewinder.check the cost of motor rewind to a brand new motor.have choose n it.have a nice day fix my rate.
May 07, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Fan would not run , so i diconected the breaker on the ouside of the house waited aprox. 15 mins. and pluged it back in. the fan tried to start and it did with alittle assist but ran backwards has anybody...
Sounds like te start capacitor is defective turn power off and mark the wires exactly like they are on the capacitor. Some capacitors are dual meaning they start the compressor and fan together. But if the fan side is bad it will try to start and after too many attempts will damage the fan motor. Let me know if I am helpful or if you need more assistance. Sea Breeze
Jul 11, 2009 | Goodman CKL24AR24 Air Conditioner
My air conditioner fan motor runs in reverse thus, none or very little air is coming out
The fan motor can be wired correctly for up flow and still run backwards for downward flow or reverse when you put the wrong value capacitor or connect a hard start capacitor to an already bad start dual cap. Case in point: I come across a condenser where the fan motor is running (in the right direction, up) but the compressor is not. I put a hard start cap on the dual cap. The compressor comes on but now the fan motor runs reverse. No other wiring was changed. The hard start cap connected to the defective compressor start cap shifted the current, voltage phase 180 degrees to make the fan motor run backwards. I removed the hard start cap, removed the defective dual cap and replaced the dual cap with a known good one and everything worked correctly.
Jul 09, 2009 | Heating & Cooling
Condenser fan running backwards on heat pump
I am having the same problem, sometimes it runs in the wrong direction, blowing the air down. Sometimes something gets tripped and I need to turn the thermostat to off and wait a bit then restart it. If I am lucky it will run int the correct direction and also will warm the house. Sometimes it send nothing but cold air to the house's forced air.
Jun 13, 2009 | Goodman CKL24AR24 Air Conditioner
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
205 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
