I have a 50" LG plasma TV - model 50px1D (3 and 1/2 years old.) Recently, one or two vertical black lines have appeared on the screen. Initially, they would disappear about 15 minutes after the TV was turned on. Now, they come and go at irregular intervals, Sometimes remaining on the screen for hours at a time. The lines are uniform, but sometimes thinner or thicker than they were the day before. Any suggestions?
    Brigadier General:
  • 3,917 Answers
A line conditioner or rerout your cable from where it comes into your house to the TV.
If no, you should check your power supply board. The capacitors on the power board are likely going bad. Don't keep using it like this. Either check the board, buy the same value caps and replace them, or order in and replace the entire power board. The latter is the easiest to do. Remove rear case and inner shield, replace the power board and reassemble.
Thank You
Posted on Jun 01, 2009
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
I have a 4 yr old LG 50PX1D plasma tv and it works fine for about 20-30 min then the screen goes black. If you turn it off for an extended period, then back on, you can watch for another 20-30 min. Any...
Its either the XYZ circuits, power supply, or bad ESR conditions starting to develop. Have your local shop repair it for you....
The set is 4 years old, and usually problems in Plasma tv's develop before then......
Nov 17, 2009 | LG 50PX1D 50 in. Plasma Television
I have a LG 50PX1D-UC plasma TV with a black vertical line
You could have a Driver Board that has a loose connection or a Ribbon Cable that has a intermittent connection to the Plasma Panel, or a defective Plasma Panel. Either one could cause the problem and I would recommend only a Qualified Service Person to check it out.
Here is LG's Customer Service Number. 1800-243-0000. They could direct you to a Local Service Facility.
I hope this helps,
Sky Assoc
Oct 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
I have a lg 50px1d 50" plasma tv that has 2 vertical lines down the screen what can I do to fix this?
Sounds lik a bad buffer board. you will probably have to have a tech replace it.. could be big $$$. get an estimate first.
Oct 23, 2009 | LG 50PX1D 50 in. Plasma Television
Vertical lines on LG 42 inch
check your LCD connectors. also video memory.
May 29, 2009 | LG 50PX1D 50 in. Plasma Television
Vertical lines on LG 50PB2DR
You need to replace the control board
May 22, 2009 | LG 50PX1D 50 in. Plasma Television
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
