This bike has a problem with firing up, i changed the spark plug and the wire to the coil, it started, but after about a week of time it wouldnt start again. what think the problem is ??
Hey,
The 'wire to the coil' that you mentioned could be the problem! (They ain't meant to be taken apart.)
You see, these things are built and operate as a unit, and must be replaced as such.....
Go to a bike wreckers (dismantlers) and source yourself another coil and spark plug lead assembly and refit.
Then, as long as you have a good battery, spark at the plug, and fuel, the old thang should fire up and run OK......
Good luck, mate....you've got a groovy little bike there. :oD
What year is your CB100? It is a CB100 isn't it? CL100? Does the bike have spark?
