Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Washer--LD message
My washer is 4 years. Haven't had any problems with it so far. It will try to start washing and then after a few minutes it will give me a LD message and not do anything after that.
  • Melissa35 Jan 14, 2008
    Washer is 2 years old. Started noticing clothes weren't completely wet after complete cycle. Sears repair men have been out 5 times since Dec. 21st. Have replaced small white pump that controls how much water enters the tub, have also replaced control panel twice. Still not working, washer washes dry clothes. They are coming again this week to try another white pump, otherwise, they don't know what else to do. Sears has been very hateful on phone b/c washer isn't under warranty-obviously Calypso model has multiple issues, becaus they told me they don't even make it anymore b/c of all of the problems, yet they won't help us either.
    Any other suggestions that I can share with the Sears repairmen? Thanks, Melissa
  • 240 Answers
The LD message stands for "Long Drain".  Two possibilities could be causing this problem.  The pump could be bad, or you could have a clog in the sump.  Pull the unit out, tilt it back, and remove the bottom panel.  You need to find out if its draining at all, or none at all.  If its just a trickle, you probably have a clogged drain sump.  Bra underwires have a habit of collecting in that sump, then lint and everything else grabs on to it, and bingo, you have a clog.  Problem is, to clear the sump, you pretty much have to strip the unit down to the tub.  Not a very easy job, and usually need a special spanner wrench to remove the nut on top of the u-joint.  Let me know how it turns out, and if you need further information.  Be sure to check your drain hose for kinks or clogs as well.  Good Luck!!!!!    Jim
Posted on Oct 24, 2007
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
When running wash cycle, the washer stops during initial cycle when water is going into tub. The "Ld" error code comes up on the panel and sometimes it is accompanied by a humming sound. Can not start...
LD is long Drain.
You'll need to crawl underneath and disconnect the hoses to check the traps for obstructions.
Have a pan handy to catch the water.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer is not completeing "normal" was cycle
could be or you may have a problem with the lid switch ( Ld )
Aug 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer error code problem
LD is long drain associated with two problems the drain hose install and the pump. Debris in the pump and a drain hose inserted too far will cause most of these issues.
Sep 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
250 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
