Question about Acer Aspire 5920-6335 Laptop
Can't get the system to boot in any configuration
My girls computer will not boot in safemode, normal, last good configuration.... i'm getting nothing, just keeps rebooting what can I do?
  • Acer Master
  • 4,806 Answers
Hi there.
The system files have become corrupt so it won't start properly, the only option left for you to do is recover the system.
If you didn't get any recovery disks with the laptop then you must use the recovery partition.
As the computer starts you can try ALT+F10 or CTRL+F10 during the initial boot cycle - this will prompt the laptop to access the recovery partition on the hard drive.
Good luck
Posted on Jun 01, 2009
  • Lee Hodgson
    Lee Hodgson Jun 01, 2009
    Just to inform you, you are going to loose some data!!!
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Message saying windows did not start properly. recent hardware or software change may have caused
There must be a corrupted software drivers.
For quick solution tried to boot in safemode then perform system restore, if it doesn't work tried to restore the last known good configuration.
How to boot in safemode:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
  4. Once your on the Windows desktop, click on Start>All Programs>Accesories>System Tools then select System restore
  5. Choose the recent date or restore point that your computer is working fine.
How to boot in Last know good configuration:
  3. When the Boot menu appears again, and the words "Last Known Good configuration" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Jul 13, 2011 | HP Pavilion a1620n (882780664494) PC...
My computer says configure updates and then it automatically turns off
This will be a long process of troubleshooting and may end up of restoring your computer to a factory settings. You can try the steps below:
First is boot up to advance boot options, to do this follow the steps below: -Turn off your computer -After pressing the turn on button start tapping F8 key until you see the Advance Boot Option. -Try choosing Last Known Good Configuration if it fail try Safemode, Safemode with networking or safemode with command prompt, if one is successful use system restore to restore your computer to an earlier date but if it fails you'll need to use your Operating System Disc to use the repair option.
Here's how to access system restore incase you're able to access Last Known Good Configuration, Safemode, Safemode with networking or safemode with command prompt: Windows XP: Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
Windows 7 and Windows Vista: Click Start, point to Programs, point to Accessories, point to System Tools, and then click System Restore select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
If you're on safemode with command prompt: At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER, System Restore window will pop-up then select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
If all the steps above fails you need to use the recover disc or the operating system disc to do a repair on your computer. Revert back in case you need steps for using start-up repair.
Note: If the steps above and start-up repair fail there's no other option but to restore your computer to factory settings.
Apr 21, 2011 | Acer Aspire AX1700-U3793A PC Desktop
Hello, I have an Acer Aspire 5532 and the battery died while it was unplugged. Usually I just plug it up and press the power button and it will ask if I want to load Windows (normally, safe mode, etc.). I...
hi,
Try the below steps:
Shutdown the computer and Restart it, as soon as it restarts keep on tapping F8 key, now select, "Last Good Known Configuration" and hit "Enter" key. It should take care of the issue. If not, then boot the computer to "Safemode", to do so, restart the computer and as soon as it restarts keep on tapping F8 key, now select "Safemode" from the Advance boot menu. If it is booting to Safemode, then perfomr a system restore to previous date. If nothing happens, then you have to perfomr a full system restore.
Jul 30, 2010 | Acer Computers & Internet
Booting problem operating system not open due to compusec application
Please do the following:
> go to the advanced boot menu by tapping on F8 right after pushing power button until you get to the advance menu screen
> you can either try to select last known good configuration or safemode by using up and down arrows to highlight then press enter
> if you select last known good configurations then system able to boot to windows then you can just uninstall the compusec apps
> if still could not boot after selecting last known good, enter Advance boot menu again and select Safemode or safemode with networking, then if you are able to boot windows again remove the apps that have a problem
> if all has been done but still having issues, i would advise to get help with backing up files from harddrive and restore system to default just like the first time you got it
> most laptops have one key recovery so check if your have
Jun 03, 2010 | Computers & Internet
E-machine gets the blue screen that says.....stop 0x0000007E(0xC0000005, 0x8053A593) what does this mean
A registry error or device driver is causing this. Attempt a boot to safemode by tapping f8 after the computer boot logo screen and before the windows logo screen.
if you can't boot to safemode then try the same key sequence but select "last known good configuration". If this does not work, then you will have to repair reinstall the operating system.
if you can get in safemode or last known config, make sure to run a spyware/virus check if you didnt' install any programs, devices or used a registry cleaner like CCleaner
Feb 14, 2010 | E-Machines eMachines Desktop PC
Hi there, I updated an Emachine T 2742 running on XP to service pack 3. The systems starts up in safe mode. Can't get it to install graphics driver. Can't run it normal. Please assist.?? harold
Try this out, Power on your PC, as you are doing this, Keep tapping the F8 key, you should see the options available for booting there, so just select normal, if it happens again, repeat the same process and select last known good configuration. If again it goes into safemode, then do this, : After booting in safemode, right click on your harddisk, then go to properties, then select Tools, then you'll see error checking, just click on Check now, then it will prompt you that it will do it at the next system restart,
Jul 11, 2009 | E-Machines eMachines Desktop PC
My system wont boot gives me options restart in SAFE MODE SAFEMODE WITH NETWORKING and LAST KNOWN CONFIGURATION OR NORMAL WINDOWS THEN COUNTS DOWN FRON 25 THEN LOOPS OVER AND OVER
when u power up the computer press F8 key then select safe mode with arrow key thne enter in "safe mode'
then go to start menu run type in run "chkdsk /r"
then press "y"
then restart computer then it fix error on harddisk.
Jun 12, 2009 | IBM (01K6743) 350-Watt Power Supply
Operating system is .............
power on the computer, immediatly tap f8 until you get to the boot menu. Choose "last known good configuration". If this fails, your master boot record is corrupt.Boot into safemode, copy all of your data to an external hard drive, then reload your operating system from the secondary partition on your hard drive or insert your OS restore disk and follow the directions.
Mar 20, 2009 | HP Pavilion dv6000z Notebook
The system is getting restart continously,while booting
  • 1. Got to your Start menu and select “Run” option.
  • 2. Type in msconfig command and click OK. The System Configuration Utility program will then open.
  • 3. Select the BOOT.INI tab located at the top of the System Configuration Utility window.
  • 4. UNCheck the box labeled /SAFEBOOT and click OK.
  • 5. When asked if you prefer to restart the PC immediately, or Exit Without Restart, choose to restart the computer manually.
  • 6. Your computer will automatically boot into Windows XP Normal Mode when you will restart it.
Dec 16, 2008 | Microsoft Windows XP Home Edition
Acer Aspire 5920-6335 Laptop Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
