Question about Boating
1994 Suzuki DT 9.9c outboard engine oil light on, but engine not.
The engine was running fine but now the oil light comes on despite the fact that it has oil and now it refuses to start. I was out fishing of course when this happened.
Help!
  • 5,501 Answers
It sounds like the oil cutout switch is bad. It is suppose to save your engine from running low on oil. Several things. Engines that use these switches may have two fill plugs. One is higher than the other meaning it has to have more oil to top it off. Next is the angle of the motor when it is on the boat. All the oil will go to the low side of the engine. If the oil shutoff is on the high side it thinks you are out of oil.
Posted on Jun 11, 2009
1993 Suzuki 4hp 100.1 how much oil per gallon
the manual shows for a 100 :1 mix the ratio is 4 ounces of oil to 3 gallons of fuel
there are two engines and one is 50: 1 ratio so that would be 8 ounces of oil to 3 gallons of fuel
there is a pdf version workshop manual at www.motoren.ath.cx and it gives the ratios for all of the 4hp suzuki outboards and the oil to use
Oct 01, 2016 | Clymer Suzuki 2-225 HP Outboards Includes...
The two check eng and temp lights do not come on when I first turn switch to start on. Suzuki 60 2014
check the oil pressure first with a test gauge, as far as the other light goes have you over revved the engine?
May 22, 2016 | Suzuki Motor, Power Trim, DF60-70 98-00,...
2000 150 DT. What is causing it to miss?
a misfire
is cause by you missing TUNEUPS
and seems you drove it dry of oil
doom
Jan 04, 2016 | Suzuki Cars & Trucks
Check engine and oil lights come on when riding
check their must be some kind of a oil pressure unit check if the terminal is connected properly or replace the unit
Jan 07, 2014 | 2006 Suzuki GS 500 F
Suzuki outboard motor dt 28 will not spark
Have you checked the kill switch,make sure all earths are grounded
Dec 02, 2013 | Suzuki Outboards - Zinc 115-140Hp Outboa
Yamaha dt 125 red oil light has just started to come on,oil through small round window looks half full..is this right...
Yes , time to top up the oil, Yamaha just want to give you plenty of notice, cause nothing will destroy the engine quicker than running out. I would be topping it up as soon as you see a bubble in the window.
Apr 03, 2010 | 2005 Yamaha DT 125 X
Suzuki outboard dt 60 no power
try removing the prop when you want to barrel test it . we (evinrude) dealer had to use test props or remove on bigger engines . or run in river /lake
Mar 14, 2010 | Boating
Suzuki outboard DT 140 tilt trim switch worked fine the other day .now it wont do anything no noise or movement or anything
Check all wire connections, Check switches at binical and at pan on engine. Bill
Oct 04, 2009 | Boating
I have a Suzuki DT65, all is fine until motor warms up then i loose mid range, it's either idle or flat out, can someone help with this problem.
have a Older DT65 and the MOTOR is clean but wont tur over and sounds like a bearing in grinding or somthin
Aug 12, 2009 | Boating
1996 Mercury 150 Nitro EFI outboard- just bought the boat, running fine on the lake for about 35 min. Motor is 2 stroke- oil injected, oil tank is full. While running at partial throttle, an alarm...
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Jun 13, 2009 | Boating
Boating Logo
441 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
