Question about Fujitsu Siemens LifeBook S-6000 Notebook
Have ide drive have put a new 60gig but cant load new os it finds the cd drive but wont boot from disk have changed bios but still it say ntdlr missing it drivin me nutts.
    President:
  • 2,559 Answers
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows.
  9. Loose or Faulty IDE/EIDE hard disk drive cable
  10. .
To Fix
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot
Posted on Jun 01, 2009
  • 674 Answers
Change you CD room drive.. and CD OS then boot and format all.. after the formating install untill done.
I have installed windows 2000 server and i am getting problem in booting of os. when there is cd of ms2000 present in the cd drive the os boot properly while if i remove cd from the drive and start the...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Apr 15, 2011 | SuperMicro X6DVL-EG2 Motherboard
Boots only to bios settings, then blank screen after save and exit. will not take a cd boot.
Hello, since it can boot to bios setting, then have you try configuring the boot order,the cd drive should come first,after that your hard disc, if the hard drive comes before the cd rom then it would not recognise it. Change the settings and Save this settings, then try to boot from the cd again, if this does not work then i am rest assured that your hard drive has a problem,and you need to find solution to it by getting a new one. cheers Regards
Dec 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
Hi all! I have a 4 year old PC with 2 HD's , one is IDE and the other one which is newer is SATA. Once in while i get this boot error saying NTDLR is missing. What the computer does is resets the hard...
You question is not very clear. When you set the BIOS, you say it works well for several weeks. Does it change again automatically? If this is the case, replace the CMOS battery. (Usual battery model is CR2032).
If you have WinXP installed on both HDDs, set to view hidden and system files, and copy the NTLDR file from SATA disk to the IDE disk. If your NTLDR files goes missing from time to time, it is definitely a virus. Use a reputed AntiVirus software (I recommend Kaspersky).
If it is a boot virus, - first backup your files to CDs. - Remove partitions from both HDDs.
- Reset the BIOS. - Restart the computer and install OS. - Install a good VirusGuard.
Nov 12, 2010 | Computers & Internet
I want to istall a new Hard drive, and I want to
Assuming you don't already have a second drive with an OS loaded then you will just need a boot disk or a Windows XP installation disc. Install the drive and then insert the CD. Power the PC on with the disk in the drive an you should get a message to boot from CD, just answer yes (note: the PC may boot automatically off the CD). If this doesn't work then you will probably have to go into the bios and change the boot order to make the CD as the first boot source. Entering the bios is different on each PC so, you will just have to find out the key sequence, usual buttons are ESC, F2, or CTRL+DEL.
Nov 17, 2009 | HP Pavilion Elite M9400F PC Desktop
Boot error always
Hello sir, hi your boot error can be caused by the following:
  1. Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
  2. Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
  3. IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
  4. Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
  5. Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
  6. Your IDE ribbon cable is bad.
  7. Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
Nov 08, 2009 | ASUS P4S8X-X Motherboard
I JUST CHANGED MY HARD DRIVE FROM 80GB TO 160GB BUT IT WILL NOT LET ME IN MY PC COMES UP PXE-E61: MEDIA TEST FAILURE CHECK CABLE PXE-M0F:EXITING BROADCOM PXE ROM NO BOOTABLE DEVICE- INSERT BOOT DISK I...
When your new hard drive is installed does the Bios see it?
If not then you have an issue with the hard drive. Quite often this issue can be resolved by simply removing the IDE cable blowing out any dusk and reattaching it.
If that doesn't work try disabling the LAN boot option. You can also try changing the HD from ACHI to EDI, changing the Boot order and/or simply resetting the bios.
Try these and if you have no go for launch repost what you did and I'll try and help from there.
Hope this helps.
Oct 22, 2009 | Acer Aspire 5315 Notebook
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
ASUS P5S800-VM Motherboard set up
Hi m_k_bishop,
You must connect the CD-RW drive to the Secondary IDE connector on your board.
It can not be connected to the Primary IDE port.
(All SATA drives are seen as master drives in the bios).
With that in mind there shouldn't be any data cable connected to the Primary IDE slot.
When you first load the Bios menu screen you should see your CD-RW listed & you should see your SATA drive listed. Go to the title, " BOOT " in your bios.
(If your system has a floppy disk drive connected your Boot menu should read as follows);
First boot device [Floppy Disk]
Second boot device [Your CD-RW drive]
Third boot device [Your SATA drive as shown from the main menu]
No need for a fourth device.
Save the bios & exit. The system will auto restart.
(At boot up re-enter your bios).
Next change the [RAID Mode] to SATA or Enabled anything but RAID.
Once completed save & exit the bios. If everything is connected correctly & you made the changes above your system should see your SATA drive & windows should install.
(Load the windows CD into your CD-RW drive).
The Asus manual lacks the proper information needed for you to make the correct setting changes in the bios.
Good luck m_k_bishop!
Post back if still have trouble... You shouldn't!
Mike
Mar 21, 2009 | ASUS P5S800-VM Motherboard
ABit-Th7 raid Drivers
This problem is very simple.... Using RAID in booting in cd/dvd cannot be done in this kind of processing. you have to change the setting of Hard Disk and CD/DVD to IDE in BIOS . To change the setting in the BIOS you need to press the Delete After you power on the computer.. In Main menu in the bios you will find the hard disk or cd/dvd settings to IDE, SATA, and RAID. change both hard disk and cd/dvd to IDE configuration. make sure the first boot in the Boot menu is the cd/dvd, where your windows cd installer is inserted. Save the settings by pressing F10 key in the keyboard.. I have the same problem as of you because i try it to change SATA, RAID but cannot boot to cd and cannot detect the hard disk when installing OS, but in IDE settings its okay.. and it works perfect.. after you installed the windows properly, you can change the Hard Disk or cd/dvd configuration to SATA or RAID. TY
HOPE I CAN HELP
Dec 08, 2008 | Abit KT7A-RAID Motherboard
Fujitsu Siemens LifeBook S-6000 Notebook Logo
428 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
