Question about Campbell Hausfeld Air Tools & Compressors
1/2' Impact wrench does not work.
When trigger pulled air bleeds by in front without turning driver. Is there a repair kit to replace seals?
    President:
  • 2,559 Answers
Yes,Just look up a seal kit for your brand on google
Posted on Jun 01, 2009
Kobalt 350 impact runs without trigger pressed
Sounds like a problem with the throttle valve.
you will have to remove the air inlet (item# E) then pull the spring out (item# 37) and look to see if you find any foreign objects, if not the proceed to pull the throttle valve (pin cover) (item# 37) and check the seal (item# 34) for wear.
Follow this link for the parts manual:
http://pdf.lowes.com/useandcareguides/879686002796_use.pdf
Dec 31, 2013 | Kobalt 350 ft-lbs Air Impact Wrench...
Cleco 3'4" impact blows air when trigger is pulled and barely turns?
It is difficult to say for sure what the cause is without seeing and hearing this tool running, or attempting to run.
My experience with this tool would lead me to look at the throttle valve first (it's the easiest to get at). Many times the seal becomes rubbery and will block the air flow to the motor. The other likely culprit will be one or more of the rotor blades(vanes) rubbing on an end plate. Gently sand either end of the vane until it is about .001 inch shorter than the rotor. Lastly, rust scale or dirt in the motor will also cause this condition.
This tool has been out of production for many years and parts are no longer readily available.
I hope this helps.
Dec 01, 2013 | Cleco Dresser Ind. Mod Wt-2100 1" Air...
STUCK TRIGGER
The I.R. 2135Ti or TiMAX has some known issues with the trigger o-ring (item# 22A) swelling, the throttle valve (item# 28D) bending or breaking, and the throttle valve seal (item# 28E) wearing out or deteriorating. Procedure wise you should not be able to remove the trigger without first removing the inlet bushing assembly (item# 26) the reason is that the reverse valve (item# 24) keeps the throttle valve from tipping forward and releasing the trigger, there is a slot for the stem of the throttle valve to slide into.
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
When reassembling the tool first install the inlet bushing assembly and then install the trigger, make sure to lube the o-ring before inserting.
Oct 17, 2012 | Ingersoll Rand 2135Ti Air Impact Wrench
As soon as the air is connected wrench starts turning. No trigger control. Thanks!
a rubber seal/o-ring is either wore or broke inside or one of the internal components are stuck, do you regularly oil it? put a couple drops of oil in where you connect the air line and let it work itself through with it turning. Might loosen it up
Jan 18, 2011 | Sears SK Pro Gun 1/2-inch Impact Wrench...
My pt501 Porter Cable air impact wrench won't turn off
Your throttle valve seal is bad or your trigger pin is stuck. Go to ereplacementparts.com and type in your model# this will give you a detail of the parts broken down.
Dec 03, 2010 | Porter Cable Cable 1/2" Impact Wrench...
My air impact runs without squeezing the trigger.
if u take the tail outa ur gun u will see that da gause filter inside has broke up.it gone inside and holding da valve open pick it out wit a seal pick r somethin
May 27, 2010 | Ingersoll Rand Air Impact Wrench 1/2in....
Hi, The socket adapter spins before i engage trigger
The seal is bad inside leaking air pressure to the gun without squeezing the triger. Get a reseal kit from Sears
Jan 22, 2010 | Craftsman Tools 1/2" Air Impact Wrench...
Throttle valve is rotten and tool runs when you plug in the air without pulling trigger
there is a neoprene O ring in the trigger area ,that breaks down ,it needs a service by an air tool repairer ,it is not expensive. dont use wd40 or the like if dont have airtool oil use auto transmission fluid and this wont happen too often
Oct 18, 2009 | Craftsman 1/2" Impact Wrench
Where is the o-ring for the air intake
The problem is in the trigger valve and is a very common problem with these and other brand, some even do that when new! Most people just live with it but you can dissassemble the gun and try.
Jun 21, 2009 | Impact Husky® 1/2" Wrench
No pressure when pulling trigger, trigger sticks in handle body
if air sound comes out when you press trigger your pressure regulator pin is stuck-oil gun and attach hose repeate until pin frees or remove pin and clean with brake kleaN oil and replace
May 31, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Air Tools & Compressors Logo
283 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
