Question about Dryers
Gas dryer runs but no heat
Estate gas dryer model tgds780jq1 runs but won't heat.
    President:
  • 1,136 Answers
Hi, Remove the little cap on the front panel lower left corner and start the dryer. Look into the hole and see if the ignitor glows (5 - 10 seconds)
If the ignitor does not glow, try this: Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
If the ignitor glows and then shuts off before you see a flame, try this:
Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto. I know this is a lot of info but, it's the most popular problems.
Please let me know if this help or if I can assist you further.
Vic
Posted on Jun 01, 2009
Dryer tumbles but won't heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Estate Dryers
Whrilpool estate dryer model egd4400sqo not heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 20, 2010 | Estate EGD4400SQ Gas Dryer
REPLACING HEATING ELEMENT IN ELECTRIC ESTATE WHIRLPOOL DRYER
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 27, 2010 | Whirlpool LEB6300 Electric Dryer
Will not put out any heat
heatman101
Jun 20, 2010 | Estate TEDX640JQ Electric Dryer
I cant lite the pilot
heatman101
Jun 10, 2010 | Estate TGDX640JQ Gas Dryer
My whirlpool estate electric dryer stopped heating up. Everything else works fine. Is the problem the heating element ?
heatman101
May 31, 2010 | Dryers
Dryer not heating after power surge
heatman101
May 14, 2010 | Estate EED4300TQ Electric Dryer
Dryer runs but no heat
heatman101
Mar 13, 2010 | Estate TGDS740JQ Gas Dryer
Electric dryer wont heat
heatman101
Sep 28, 2009 | Estate TEDS740JQ Electric Dryer
Dryers Logo
141 people viewed this question
Top Dryers Experts
