Question about HP Color LaserJet 2600n Printer
Smearing on the bottom half of the page
My printer is brand new - had it for 2 weeks.  All of a sudden, I get a "smearing" starting at the middle of the page and getting worse towards the end.  I have done cleaning ... calibration ... restore defaults.  Everything.  When I do the cleaning, there is a small amount of ink on the bottom section of the page, not much.  But it does not solve my problem.  PLEASE HELP! It does this with b+w as well as colour
  • HP Master
  • 1,113 Answers
If it is only 2 weeks old then it is under warranty, log a job with HP - you have a faulty fuser (hot bit where paper exits), faulty black cart.orfaulty/marked transfer assy.(on door)
Posted on Oct 27, 2007
I have colored smears on left side of all my printed pages with my Brother MFC-9420 CN. What causes this?
It's not unusual for paper to hit the bottom of the print head, especially if the paper is bent. This can cause smearing. If you have pets, you can check for pet fur in the printer, or other foreign material inside that can also cause smearing.
Sep 11, 2014 | Brother MFC-9420CN All-In-One Laser...
First problem was the whole page was smearing when printing. I replaced the drum and there is still a little smearing. What can I try next?
smearing can be interpreted different ways. if paper stalls, it will cause "stretched" print. if the drive system is bogged down by a binding drum unit or toner, it can cause a "squished" print. if its just a "blurry" kind of print, it may be generic toner. since i can't actually see defect, i would say since you replaced drum already, toner would be easiest thing to do first. keep in mind also, generic toners have a fairly high failure rate.
razors
Nov 30, 2011 | Brother HL 5250DN Laser Printer
Yellow smear on left side margin from top to bottom of the page. After cleaning, the smear reduced to one third and confined to the lower left corner. How do I get rid of it entirely?
What did you clean? If it was the Image Transfer Belt (the big mylar belt in the front), do it again. Print and see if the yellow is smearing again. If it is replace the yellow cartridge.
Jan 31, 2011 | HP Color Laserjet 3550 Printer
The document printed from samsung scx 4200 printer has smudges and dots.
When you say smudges, can you wipe the toner from the page with your fingers; or is it just smearing when it prints; but, the toner is affixed to the paper?
1) If you can smear it with your fingers; replace the fuser. It's not heating the toner properly
2) If it is smearing, but sticking; replace the DRUM.
Nov 07, 2010 | Samsung SCX 4200 All-In-One Laser Printer
HP laserjet 5000gn when i print, output smears ink on 2 sides. not a toner issue cause changed toners already. someone says printer is telling me something and might be a warning of
If by smearing you mean the print is also rubbing off? Then you definately have a fuser unit issue. The fusing unit is the assembly that heats up and "fuses" the toner onto the page. When these start to go bad, usually on one edge or the other the print will smear/double image/wipe off of the effected area. One test you can do to verify a fuser problem is to print a page and then when the page is about half way thru the prcess, shut the printer off. Open the top and remove the toner cartridge, pull out the page and see if the lower part is not smeared. Basically what your checking is to see if the print is ok BEFORE it goes thru the fuser. Based on your description I would suspect your fuser is going bad.
Good Luck and Thank You for using Fixya.
Sep 09, 2010 | HP LaserJet 5000gn Printer
Yellow not installed
Are you using a factory new HP cartridge? If so, contact HP and request a warranty replacement of the toner cartridge.
Jul 13, 2009 | HP Color LaserJet 2600n Printer
Phaser 8200 Smears on Linen Paper
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
Mar 24, 2009 | Xerox Phaser 8200 Laser Printer
Vertical toner smear-off in all colours
Looks like the ridges inside the cartridge are catching. Here's a solution;
http://www.ahfx.net/weblog.php?article=133
Dec 12, 2008 | Dell 3100cn Laser Printer
My Canon i960 printer is printing red streaks on the pages
It's possible that the heads need to be replaced. That's one disadvantage to the printers that don't have the heads contained within the cartridge.
Feb 26, 2007 | Canon I960 InkJet Photo Printer
HP Color LaserJet 2600n Printer Logo
158 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
