You may have information in temporary memory that has not cleared for some reason. Try a hard reset. The hard reset will not delete saved files on the hard drive. To perform a hard reset, follow the steps below.
* Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
* Remove the battery from the notebook battery compartment.
* Press and hold down the power button for about 20 seconds. NOTE: Holding down the power button while the computer is turned off drains any residual charge in the capacitors.
* Insert the batteIry and plug the AC adapter back into the notebook PC.
*Press the power button to turn the notebook PC back on.
Hi Sony notebook computers must be taken apart to reset the BIOS password to the factory default when the current password is forgotten or simply unavailable. A small battery inside the computer must be removed for a period of time in order for the password to reset. This requires notebook repair skills specific to Sony notebooks, and should only be attempted by a technician who is familiar with the process of taking Sony notebooks apart and putting them back together without damaging the parts. Two way to remove BIOS password. 1) Soft reset2) Hard reset Soft Reset BIOSpasswords can be reset in two ways, 1. using software 2. using hardware.
I would first try resetting using software, here are two software's to reset orretrieve BIOS passwords.
!BIOS- is a PC BIOS toolkit offering password removal/decrypt and BIOS settingsmodification/backup/restore.
Step 1 Back up the hard drive to optical discs, an external hard drive or a network location to safeguard any important files.Step 2 Shut down the computer by clicking "Start" (Windows Orb) and choosing "Shut Down."Step 3 Disconnect the Sony notebook power adapter cable from the wall and from the back of the laptop.Step 4 Close the lid and flip the notebook over to expose the bottom screws and compartments.Step 5 Remove the main battery from the bottom of the Sony notebook.Step 6 Remove the compartment covers for the RAM and the hard drive.Step 7 Remove the hard drive by unscrewing the bracket that holds the drive in place and pulling gently on the drive until it disengages from the socket.Step 8 Remove the RAM by spreading the small metal retention clips that hold it into place, and then pivoting the RAM up slightly and pulling it out of the sockets.Step 9 Remove each of the small screws from the bottom of the Sony notebook, and place them on a clean, flat surface in a pattern that represents which hole each screw came from.Step 10 Gently flip the Sony notebook right-side up and open the lid.Step 11 Separate the base of the Sony notebook from the upper case by gently pressing the plastic knife or credit card into the seam and pulling the top away from the bottom.Step 12 Disconnect the wire that connects the small coin cell battery pack to the motherboard, or remove the coin cell battery from the socket, depending upon the model of the Sony notebook. Some models may require that the motherboard be removed from the case in order to access the battery.Step 13 Wait one hour with the battery disconnected and reassemble. The BIOS password will be cleared and the computer will boot into the BIOS setup program or to the operating system. This process does not clear any operating system passwords.Tips & Warnings
Reset a known BIOS password on Sony notebook computers by entering BIOS setup using the "F10" key on startup. Enter the existing password, and navigate to the security screen in the BIOS setup program to choose a new password. Consult the owner's manual for specific instructions on particular Sony models. Use a blank piece of paper to set the screws as they are removed, marking them or arranging them as necessary. It is important to replace the exact same screw into each hole that it came out of as there are often several different s of screws.
Notebook computers are assembled with small, delicate plastic tabs that are easily damaged. Internal cables and assemblies can be broken or damaged with relatively little force. Leave this technique to a professional technician if unsure of how to take a Sony notebook computer apart. Do not let the computer go into sleep or hibernation mode or simply shut the lid as this is not a full proper shutdown and the hard drive can become corrupted if the computer is not properly shut down for this operation.
Sometimes it is necessary to do a hard reset to erase all of the information in the temporary memory and regain functionality of your PC when it stops responding. For example, doing a hard reset is helpful if your keyboard quits responding, you cannot get your PC to come out of hibernation or sleep mode, or if a software program causes the PC to freeze. The hard reset will not delete saved files on the hard drive. Performing a hard reset To perform a hard reset, follow the steps below. 1-Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station. 2-Remove the battery from the notebook battery compartment. 3-Press and hold down the power button for about 20 seconds. NOTE: Holding down the power button while the computer is turned off drains any residual charge in the capacitors. 4-Insert the battery and plug the AC adapter back into the notebook PC. 5-Press the power button to turn the notebook PC back on
You need to perform a Hard Reset here are th steps. Hard Reset is a method by which we discharge the capacitors of the Notebook and try to regain the functionality. It resolves the hardware and software conflict. It will not erase any data present on your Hard Drive. To perform a hard reset, follow the steps below. Note: Please turn off the notebook if its on. Step 1: Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station. Step 2: Remove the battery from the notebook battery compartment. Step 3: Press and hold down the power button for about 20 seconds. NOTE: Holding down the power button while the computer is turned off drains any residual charge in the capacitors.
Step 4: Insert the battery and plug the AC adapter back into the notebook PC. Step 5: Press the power button to turn the notebook PC back on. Step 6: Use the arrow keys to highlight Start Windows Normally , if it is not already highlighted, and then press the enter key
if this does not resolves the issue then remove and reseat the RAM of the notebook.
If still the issue persist then contact HP its a hardware issue.
Here is the link to your service manual, when you click on it and bring it up...it is a pdf file so you'll need adobe or another pdf reader, go to page 40, that is the directions for resetting and removing the BIOS/hard drive password. Good luck
