Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Refigerator light out
We have a hotpoint side by side that is 7 years old. The light went out and we have replaced the bulb to no avail. The fridge works, the freezer light and water lights work, the door switch does not stick. Any suggestions?
    President:
  • 1,136 Answers
Hi, Sometimes when you replace a bulb it feels tight but, you might have to get another 1/4 turn out of the bulb. Grasp the bulb with a towel and the palm of your hand and give it a turn. You might have to loosen the buld and then tighten it again.
I know this sounds silly but, I go to a lot of service calls and the bulb just needed turned that little bit more.
Please let me know if this helps you or if I can assist you further.
Vic
Posted on Jun 01, 2009
  • ayhllon Jul 24, 2011
    Amazing simple and works!
Fisher and pykal all fridge beeps all the time, the bulb was blown, taken out (no spare at home). Will the fridge continue to work without a bulb
If you're talking about the light that goes on when you open the door, then yes It will. The light bulb has no effect on the operation of the refrigerator.
Feb 15, 2017 | Fisher Refrigerators
Problem with fridge light on Hotpoint FFA70
Did you check the new lamp when you put it in? Did you keep the old lamp? It may well be the switch rather than the lamp itself. Check the lamp has continuity from the middle pin to the outer and the filament isn't broken
May 10, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer has bad smell, cleaned entire fridge and freezer out, no help. working fine but smells ?? side by side model about 5 years old, maytag
For odors in the refrigerator/freezer try baking soda or, for tougher odors, try Fridge Aid deodorizer, also available in the accessories section of our website. on  www.repairclinic.com
Mar 31, 2009 | Hotpoint HSS25GFP Side by Side...
Frigidaire PLHS267ZA Side by Side
Did you leave the door open? check the light socket for shorts ..check the door switch the light will go off when to door is closed..
May 04, 2008 | Frigidaire PLHS267ZA Side by Side...
HOTPOINT RLA30 FRIDGE
is the noise like a hum? touch the compressor if it is really hot, suspect relay/overload combination defective touch the little line that comes out of compressor if cold, suspect the above. if you change the relay/overload combination, and works fine there's your problem. hope to se of some help.
Apr 21, 2008 | Hotpoint RLA30 Compact Refrigerator
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
128 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
