Question about Focus Electronic Focus FK 7200 PS (FK7200PS2) Keyboard
Replacing Track ball pin rollers
I have had the FK7200 ever since they came out with them. I now have my 3rd and final keyboard with the same problem. The pin rollers under the track ball have worn down, causing the track ball to slow down and skip. That is the only problem with the 3 keyboards. Where can I find parts for these boards? who might have the correct pin rollers?
  • stacey_georg Jun 01, 2009
    Hi, The solution you gave me is for a web site that was last update in 2003. I do not see parts for this keyboard listed, but I do see the keyboards itself listed. Has this supplier been validated? I do not give my Visa card out to just anyone. So far I'm not accepting the solution.
  • 11,896 Answers
Computer parts for FOCUS Database last updated: May 26, 2009. Currently 3498768 parts ... Keyboard EPS. FK7200, FOCUS, NEW, 22, --. PSII Keyboard w/trackball New ...
www.l7inc.us/mparts_FOCUS - 32k - Cached - Similar pages
More results from www.l7inc.us »
Posted on Jun 02, 2009
    Top Expert:
  • Focus Electr... Master
  • 79,865 Answers
Go to the link for parts listings.
http://www.thecybersource.com/keyboard.htm
Posted on Jun 01, 2009
Will not move cursor from side to side.
If it's possible, take out the track ball and clean the 3 rollers that sends the signal to the computer. At times, they can attract dust, hair etc and gets very cloggy.
Hope this help.
May 03, 2011 | Kensington 64213 Expert Mouse Pro
Optical track ball is sticking. How clean it and what to avoid?
An "optical" mouse has *NO* track-ball.
If you do have a mouse with a track-ball, then rotate the "ring" that holds the track-ball inside the mouse, to "unlock" the ring. Remove the ring. Look inside the mouse. You'll see two rollers.
Look for accumulated "gunk" in a ring at the center of each roller. Gently scrape each roller, to clean it. Re-insert the mouse. Re-insert the ring. Rotate it, to "lock" the ring into place.
May 19, 2010 | Logitech 931249-0403 Mouse
Can i still send messages if my track ball doesnt work on a blackberry curve
yes...but it would be better if you just cleaned the roller pins on the trackball or replaced it with a new one.
Nov 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
Lost function on wireless mouse model kb990w
try to clean your mouse. Open and get the mouse track ball and try to remove the dust that may have accumulated on the bars holding the track ball.
Regards!
Jul 10, 2009 | Micro Innovations KB990W Keyboard and...
My keyboard and track ball do not work. I can not
Buying a new one would be very expensive. Go Visit Cell Phone Repair Center located in Dallas Tx if you are local. If you are outside Dallas you can Mail-in your Phone to them.
For more information visit www.drcellphone.com. They are the best Cell Phone Repair Service Center in the Nation.
Jun 12, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
99039URF keyboard/mice track ball not working
well u can try installing a driver that may help some times also check the batteres on the mice!
May 31, 2009 | Btc 9039URF III Keyboard Trackball...
Excavator track needs to be put back on
after the idler is pushed all the way back into the frame.try to put some wood blocks under the track to remove all the slack.use the bucket to push as much of the bottom section under the bottom rollers.use a heavy chain and pull up and over the top of the roller.when you get close you can use the drive to walk it the rest of the way.if it still doesnt go you may have to break the track at the master pin. this is usually marked with a small hole drilled in the end of the pin.heat and beat the pin out,break the track.pull track over top rollers and make ends meet on top of the srocket.use a chainfall to pull two halfs together and line them up.drive pin back in and your all set.
Mar 01, 2009 | Gladiator Gear Track Pack
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
Roller ball
Same problem, wouldn't scroll down. Lifted the ring pulled out the rollerball and cleaned it with alchohol. Used a cotton swab, soaked it pretty good and rolled it around a bit. Set it back in and it worked like new. Watch how you take it out so you can put it back in the same way.
Sep 15, 2008 | RIM BlackBerry Curve 8310 Smartphone
Focus Electronic Focus FK 7200 PS (FK7200PS2) Keyboard Logo
51 people viewed this question
Top Focus Electronic Computers & Internet Experts
David Payne
David Payne
Are you a Focus Electronic Computer and Internet Expert? Answer questions, earn points and help others
