Question about General Electric GE DBVH520EJWW Electric Dryer
Panel Turns On, nothing else
1 year old, DBVH520E. Panel will come on, hear a click, nothing else. No tumble no heat.
  • andrewkmcfar Jun 02, 2009
    Thx, is there a guide to reaching and identifying the Thermal Fuse, or the internal circuit breaker, step by step?\
    I have read out at the panel voltage to drying is good.
  • 15,935 Answers
Your dryer should have a service manual taped to the inside of the rear panel or behind the front kickplate.
It will give you the locations you are looking for, and well as the testing values of sensors etc.
Absent of any error codes - I would suggest your Main Controller board to be failing. It is really the Timer - however it is on-board the controller and not seperately serviceable. A new controller is required.
CLICK HERE to see it.
The thermal fuse would not be the problem here - as the dryer would still tumble - but not heat up.
There is no internal circuit breaker - that is located in your main circuit breaker panel of your house.
The CLICK indicates the relay for the motor engaging.
To rule out the MOTOR being bad, you would need to access the motor, and take readings at the motor after the click is heard.
No voltage after the click means the controller is bad... voltage at motor, but no spin = bad motor.
You can try a hard reset if you havent already by simply unplugging the machine for 10 minutes and re-trying. However that rarely rectifies the problem.
If you require additional assistance, please use the "Continue with this expert" option so we are connected in the future.
Thanks for using FixYa!!
Posted on Jun 02, 2009
    Brigadier General:
  • 3,917 Answers
Check the thermal fuse, the clicking noise usually indicates a faulty control timer board.
You will probably need to replace the control timer assembly.
The part must be tested before replacement.
You find diagrams and replacements here.
OR
It sounds like it is coming from behind the knob for the settings.could this be a timer issue
http://www.applianceaid.com/general.html#dead
OR
Most Electric dryers work on 240 Volts. And have their own seperate circuit breaker, usually marked as "Dryer."
So resetting just the main cuircuit breaker might not be enough.
Thank You for contacting Fixya
5 ton goodman package unit
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
My beko tumble dryer drcs68w does not heat up, i have taken the back off and checked all the connections between the heater and the control panel,if i do a reset by holding the cancell button for aprox ten...
its a trip switch, if its tripping then there is a fault with the element, it is either clogged up or shorting out when it heats up. i would think it needs replacing. becareful with dryers as there have been a lot of beco products over the years.
May 30, 2017 | Dryers
The dryer tumbles but does not heat. There is no
If you dry a lot, you may need heating coils. Heavy loads such as jeans and towels will put a premature stress on those coils.
Jun 21, 2010 | KitchenAid KEYS750LQ Electric Dryer
How can i fix my indesit is70c tumble dryer? my indesit is70c tumble dryer wont heat up during performance
open the back panel , not the the full back just the smaller panel located near the bottom half.
the termo will be screwed onto this panel . unscrew and you will see two circles near the top one will have a small pin hole in it . stick a pin in till you hear a click replace and should work fine
Mar 05, 2010 | Dryers
It wont tumble
Is the motor spinning.
Check the belt and tensioner.
Feb 28, 2010 | Washing Machines
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
WHITE kNIGHT tUMBLE DRIER THAT STILL TUMBLES WITH NO HEAT
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Sep 05, 2008 | Dryers
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
General Electric GE DBVH520EJWW Electric Dryer Logo
82 people viewed this question
Top General Dryers Experts
Tim Whalen
Sal DeAngelo
Are you a General Dryer Expert? Answer questions, earn points and help others
