Question about Mtd Garden
Ground speed slows under pull at high variable speed settings.
MTD model 14AJ84AH062 With variable speed drive in high gears the tractor slows to a stop. Front belt seems loose.
  • 376 Answers
Take off the plate around the shift lever between your legs and take a look at the belts. Most likely they will be in poor condition. You can even leave the trans in neutral, start the engine and move the speed selector through the gears and observe the belts in action. They do the same in neutral as in gear when you let out the clutch with the engine running. You should be able to see what the problem is, It will either be one or both of the belts or possibly the needle bearings in the vari-speed pulley itself,
Posted on Jun 01, 2009
MTD RIDING MOWER MODEL 13AH660F372
Your model is a shift on the go or varidrive. Not a transmission in the true sense . I have had to give the variable pulley a few shots of oil to get the pulley to work freely up and down.This video will help you understand the workings of your drive unit. How the MTD Varidrive system works Variable Speed Pulley Maintenance
May 30, 2016 | Mtd Garden
I HAVE A 1994 MTD 18HP BRIGGS WITH MOD #144Q828H118, WHILE I WAS MOWING THE CLUTCH WOULD NOT RELEASE AND THE GEAR SHIFT WILL NOT GO INTO THE LOWER GEARS. WHAT HAPPENED?
The tractor has a variable speed pulley for the 1-6 gears. You will want to check the top pulley on the shaft that is in the center of your tractor between the engine and transaxle. you may have broke the spring or adjuster.
Apr 24, 2011 | Yard Machines MTD Gold 185 HP Lawn Tractor...
I have a Yardman 604H, 46" deck, 23HP B&S motor, with a variable speed pulley drive. When I am mowing down a slope the tractor lurches forward rapidly for about 6" before resuming normal speed for a...
Sounds like it's jumping out of gear, a common fault with these. They are way to heavy for the transmision and really should only be used on flat ground. I bet the fuel tank split around on of the mounting bolts?
Oct 25, 2010 | Mtd Garden
I have a 1997 MTD 600 series with 18.5 hp(7 speed) that I always used to pull trailer with light loads for various projects on our 10 acre property. Trouble seemed to started a couple years back when I...
Did you replace BOTH of the ground drive belts?
The deck belt has absolutely nothing to do with the pulling power of the tractor.
The 600 series MTDs have a single speed transaxle with a variable speed selector to give you the different speed ranges and requires 2 belts, one from the engine (the top half of the pulley) to the variable speed mechanism and one from the variable speed to the transaxle if one or both of the belts is worn, it will cause a loss of power to the ground
Oct 18, 2009 | Garden
Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Oct 15, 2009 | Mtd Garden
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Jun 28, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
Slow Mow
Try fixing this problem by making sure the belt is installed properly.. Whenever you install a drive belt it needs to be "seated". Make sure the belt is on correctly and the first time you try it out to see if the mower will move, start out in the highest gear. Hang on as it may ****, but this is the proper way to replace and seat a drive belt.
Jun 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Variable speed belt issue
Get your model and serial numbers from under the seat. Then go to the MTD website where you can download the owners manual which should show the belt diagram.
May 24, 2009 | Mtd Garden
Belts slipping and breaking
If you are putting on the mtd belts and installing them right then you need to check bearings in variable speed pulley Also check idler and that no other pulley has been bent from installation.
May 15, 2009 | Garden
Garden Logo
463 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
