Question about Panasonic PT-61LCX66 Television
Tperk i hooked a sattlite box to tv picture is blurry
  • 87 Answers
You probably do not have a high def signal.  If you do have a high def signal you need to use either component input or HDMI input to get high def.  I f you are using RF input you picture would improve marginally if you swithced to a video input.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
Cant figure out how to hook it up, we have a sattlite box
see this hook it. use the common sense and fix it.
God bless you
Sep 22, 2012 | Televison & Video
I finally got my tv hooked up. but the color and the picture is blurry, mostly on the top. i have tried different things but no matter what it doesn't change the blurriness,and some lines come across...
Tv have a R,G,B colors lines misalignment,have picture shadows or 3D picture look alike?Yes,than tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair,by replacing like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 13, 2011 | Toshiba 57H81 57" Rear Projection...
Hi My LG 52LB9DF tv is slightly blurry - I'm not sure if it's the size or quality of the tv? Even the HD channels are slightly pixellated. My friend has a smaller tv with a much sharper resolution....
1. Your TV has a digital tuner built-in, you do not need a set-top box to receive local digital channels.
2. Try to disconnect the box, hook up the antenna directly to the TV antenna input & program the tuner, you may getting better picture.
Aug 29, 2017 | LG 52LB9DF LCD TV
Zenith 50'' TV blurry
There is internal elignment with the guns on the projection unit. They come loose. TV guy time
Mar 30, 2010 | Televison & Video
BLURRY PICTURE
Turn on your projection TV and wiggle the coax cable from your cable box or antenna where it connects to the TV. If the picture fluctuates, you know that you have a loose connection, or that the coax cable is bad.
Jun 10, 2009 | Televison & Video
Blurry picture when hooked up to direct tv.Why?
try lowering the sharpness on your tv, because if the sharpness is to high it will make NonHD objects look blurry, also try changing the input cable or type of input.
May 20, 2009 | Element Electronics FLX-2610 26 in. LCD...
HD PICTURE
Use your input button on your television's remote control.... you should have plugged the wires into the COMP 1 area on the back of your TV.  You will also need to make sure your red and white audio cables are plugged in as well (Five total plugged wires) Press the input button until you see COMP1 at the bottom of the screen... there you will find your picture and sound.
Oct 19, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Dim and blurry
try adjusting the focus control located on the flyback of the tv. good luck
Jan 31, 2007 | GE 32GT740 32" TV
Panasonic PT-61LCX66 Television Logo
90 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
