Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Mower sluggish run nunder load
Had bad gas in Husqvarna with Briggs 22hp Twin V Intec. Ran on one cylinder, the one opposite fuel pump. opened valve cov and found top rod fell off. Reset rod to rocker arm and tightened 1/2 turn. Since then mower runs but under load revs up then dies as if no gas then revs then slows as if no gas over and over with out completely dying. Ive been told prob stuck intake valve? i have observed rocker arms with cover off and both appear to be working properly. You think stuck valve could be so? Any easy way to unstick it? (chemicals etc.) If not how do I do it?
  • p0nderosa Jun 01, 2009
    Thank you Dwain, could you please tell me how I set the gap on the valves?
  • 376 Answers
The first thing you need to do is readjust the valves properly. Remove both sparks plugs and rocker covers. I stick a long philips head screwdriver in the spark plug hole in #1 cylinder (rt. side) and turn engine by hand till piston is at TDC. (both valves closed) Set int. and exh. at .005. Then do same to # 2 cylinder after turning it to TDC too. If that doesn't clear up the problem, it'll be time to go into that 2 barrel carb. Let me know. Dwain
Posted on Jun 01, 2009
  • Dwain Pippen Jun 02, 2009
    There is a 13mm nut on the rocker with a torx adjuster screw in the middle on both intake and exhaust. Loosen the 13mm nut and turn the torx screw in or out to adjust gap to .005. Hold screw in place and tighten nut. Then do other side following my first directions. I would turn the engine by hand a couple of cycles and recheck valve clearances. I don't remember the size Torx screw, but I can tell you tomorrow when I get back in my shop. Did you understand all that? :)
    The Torx size is a T-40. Dwain
My intec 22hp. Briggs moter blowing compressed air out dip stick
they all do that to some degree . some vent back to the carburetor and some use that pressure to power the fuel pump .
May 14, 2016 | Garden
I have a B&S 22hp Intek v-twin on a craftsman mower. It starts fine, runs great, but after about 10-15 min it starts skipping and will finaly die after another coupl min. As if it was running out of...
Mine did exactly the same thing until I figured out the replacement fuel cap I bought wasn't vented.I put a vented one on and away I went.Also check for a collaping fuel line,and check the screen inside the gas tank,those corrode sometimes.Hope that helps !
May 11, 2014 | Briggs & Stratton Briggs Stratton Intek V...
22hp briggs and stratton intek v-twin model number 470577-0284-e1
to much fuel either the needle valve is stuck or the float is bad tear apart the carb acid dip and clean take float submerge in gas for 20 min pull out shake next to ear if you hear liquid inside its bad
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Have 22HP BS V-Twin in a 2010 Husqvarna rider w/25 total hours. Recently won't cold start without priminig. It will crank and crank cold til the battery runs down. A shot of starting fluid and it runs...
nearly all petrol mower engines need to have the 'choke' engaged to start from cold. This enriches the fuel mixture, and is similar to priming. If there is a prime 'button' then you will probably have to use this all the time. This is normal.
However, you should check with your dealer to see if this is an unusual situation.
Aug 27, 2011 | Briggs & Stratton Briggs Stratton Intek V...
New 24 hp B&S engine running out of fuel
There is a restriction somwhere before the fuel filter, this is assuming gravity feed and there is no fuel pump for the engine.
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine starving for fuel, fuel filter very low, almost empty
your fuel pump is diaghram actuated by pulses from crankcase pressure, if you look there is a small tube that runs from pump to valve cover, pull fuel line off carb and have some one crank it over to see if it's pumping. could be pump or blockage between tank and pump, if fuel flow seems good to carb, i would pull bowl off and check for dirt and also make sure anti run on valve, the thinghy that holds the bowl on to carb is opening properly, it should open and close when you turn key from off to run, beyond that it could be you have some water in your gas.
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
683 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
