What is the specific issue you are having with the mixer that makes you feel that the motor is burnt up? There is a variety of issues we see with KitchenAid mixers, however the motor being burnt up is actually rare. If you could get me the model of the mixer (that is under the base of the mixer on a label), then I can tell you what to look for in the mixer.
The most common issues in a KitchenAid mixer, depending on the model include: gears, brushes, and electrical components.
The grease is always black, it is actually a dark brown color but looks black, over time it can break down since it is vegetable based and can leak out of the mixer.
However I find that in 90% of the cases the repairs are fairly easy and worth the repair.
If you can get more information, or if you have questions, call our customer service team and they would be happy to help.
- Colleen @MendingShed.com
If the motors had burnt out then the winding can be redone if you can get this job to a winding shop.
Other wise the motor and assmebly can be ordered from a Sunbeam service outlet. try and see if you re able to source a motor assembly from a damaged/scrapped set with a mechanical defect.
The oil leeking into your bowl is old grease that has broken down into oil and is getting past your oil seal you need to take out all of your old grease and oil replace it with hi-temp grease or a good grade lithium grease and replace your agitor shaft oil seal
Hi AQUACLAY.For starters, for your next move remember to tell your packers to pack the mixer upright...J OK, to answer your main question, your KA mixer’s internal gears are factory packed with enough grease to last a 'lifetime', whatever that means?Depending on the age of your mixer, where it’s been stored and how long it's been idle and/or how heavily it’s been used; these factors all will eventually cause the grease’s base oil to separate from its additives, with the resultant oil seeping from openings beyond the gasket and generally following the path of least resistance down to the lowest point, i.e., the agitator shaft.Gravity can be very insidious. Of course, laying our mixer on its side offers a whole bunch of other exits points for the oil. With that much oil lost, you definitely want to replace the transmission gear grease at some point in the future. The good news is that this can accomplished quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, and feel adventurous and your mixer is not under warranty.Before you start to disassemble your mixer, be sure you have the Parts List manual on hand.If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your KSM5 mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model. Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts.Besides replacement grease you might consider replacing the Transmission Case Gasket (Illus. No. 26) and “O”-ring (Illus. No. 53), too. I’d also check to make sure there is no oil residue lingering where the oil leaked when it was lying on its side during the move; particularly if it leaked out of a brush hole on the side of the mixer head.Oil and electricity don’t mix, so here’s the opportunity with your mixer apart to wipe down the path the oil took to ‘escape’. Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping. Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself. Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer. Good luck, I hope this helps. Howard, Burke, VA If this solution has been helpful, please rate it, thanks! - hslincoln
nydadinga - Sorry to hear about your fallen mixer. This is not a tragedy, and after cleaning up the grease with soap and water, it should operate normally. Your KA mixer has internal transmission and planetary gears which convert the electric motor's rotation into the mixer's rotation. The internal gears are factory packed with enough grease to last a 'lifetime' (whatever that means), and over the course of your move the shifted mixer leaked the grease inside the transmission housing. You did not mention where the 'oil' was found. Hopefully it was not exuding 'oil' from the brush cover caps located on opposite sides of the body, but coming from the planetary (the part that turns with the blades under the body). I also don't know how old/how used your mixer is. The older the mixer, the more used it is, the more fluid the gear grease, and tend to seep from cracks and gaskets that aren't tight. Gravity can be very insidious. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. You can download it from KA customer care. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number and select the Part List file that is listed. I hope this helps! Howard, Burke, VA
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
