Question about GE Advantium 120 Convection/Microwave Oven
Replace handle on adeantium sca1001fss01
I've got the top screw exposed but can;t figure out how to expose teh bottem screw to replace the handle on the door
You have to take the door off and pop out the plastic molding around interior of door. You can do this by sliding a screwdriver around the edge until you can get your fingers in. Be careful because there are some small plastic tabs that will break very easily. Next, remove screws on the backing of the door. There are similar tabs holding the backing on even after the screws are removed. I used a pair of insulated pliers and used the handle to pry the tabs back. Be careful because the tabs will break easily. Then the screw handle is exposed. Pretty easy huh?!!!! I just comleted this process and am looking for a handle. I am sure I will have to super glue some areas since I broke the tabs off.
Good luck
Posted on Jul 04, 2009
How to replace door handle
open door
lift up seal of door to expose srews then remove
sperate seal and inside door glass
that exposes screws for the handel remove and replace
Jun 30, 2012 | GE JVM1330BW/WW Microwave Oven
E30so75fps loose handle
Amanda,
You need to carefully try to remove the plastic frame around the outside edge of the inside of the door and hopefully that should expose the screws that you need to tighten for the handle. I say carefully because that frame can be very expensive to replace if you break it. It is currently listing on Sears site for $95!
Jun 06, 2012 | Electrolux ICON Microwave Combination Oven
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace handle model #FMV156DCC
Pry the plastic trim which surrounds the glass window which will expose the screws...
Jan 27, 2010 | Frigidaire Microwave Ovens
I oderered, & received a new handel, to replace the broken one.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
It will give you safety info and step by step help in disassembly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 25, 2009 | GE Advantium 120 Convection/Microwave Oven
Replacing door handle on GE advantium
We have the service / repair manual for this model and have uploaded it to our site here (or here) for free download to help you.
You can find helpful exploded view diagrams and order parts & accessories by entering your full model number here.
Aug 01, 2009 | GE Advantium 120 Convection/Microwave Oven
Replacing door handle of Whirlpool GH6178XP
I kept prying on the frame case until it disengaged, came loose and exposed the bottom screw.
Feb 17, 2009 | Whirlpool GH6178XPS Microwave Oven
Advantium 120 door handle breakage
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 01, 2008 | GE Advantium 120 Convection/Microwave Oven
Kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Jan 27, 2008 | Microwave Ovens
GE Advantium 120 Convection/Microwave Oven Logo
578 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
