Question about Konica Minolta magicolor 2430 DL Laser Printer
Ink smudges when the document has printed, it has smudges of blue, black & pink along the EDGE of right side of paper. Looks almost like wet ink that has dried. It is heavier along bottom half, and smaller along top half.
  • AMCN Nov 04, 2007
    Printing page one I have a stripey smudge about 1/3 in from RHS of page.
    at page 3 the stripe has become a 2cm square stripey smudge halfway down the page.
    I am not sure where to start. I began just before printer signalled it needed new cartridge. This was replaced and it is still there.
    I am not sure what to look for.
    Advice would be appreciated!
  • 214 Answers
Pease check:
thet consumables is originals,
drum cartridge is not damaged
transfer belt is clean and not damaged.
you may have problem there, but if not you can try update firmware, maybe its a firmware problem.
first check consumables and if possible try changing them
Posted on Dec 07, 2007
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
I have a Canon Imagerunner 1023if and have black smudges along the left edge of paper, both copies and printed directly from computer.
this is possibly a problem in the fuseing part of your machine, where the paper heats up at the back, the fuser roller could be worn out. and your toner could be sticking to it.
Sep 05, 2012 | Canon imageRUNNER 1023iF Black and White...
HP 1300 -- toner is smudged along the left edge after crinkly sound
This is a common problem with some HP printers. The fuser sleeve inside the fuser assembly gets torn along the edge and print can no longer be fused in that area and the paper will crinkle there. The only solution would be to replace the fuser, which for that printer it would not be worth repairing.
Jun 08, 2012 | HP LaserJet 1300 Printer
I got smudges when i print ,how can i clean this
It looks like you've managed to get some ink on the rollers. 3 Possible solutions:-
1) Check your printer maintenance menu, there may be a roller cleaning option.
2) Print a document which has printable data on almost all lines, but with empty cartridges. You'd be using a piece of paper more or less as a mop.
3) Final alternative, it getting right into your printer and cleaning it by hand. Printer ink is water soluble so damp cloths/cotton buds should be man enough for the job. The parts you need to concentrate on are the rollers and the small sponge wells underneath where the print cartridges rest.
Apr 13, 2010 | Computers & Internet
Printing has smudge on edge
If it is right along the edge then the drum (well the cleaning blade of the drum) is faulty. In a unit like that I suspect it is all part of a toner cartridge. Try replacing that and I think you will be good.
Jan 01, 2010 | Epson AcuLaser C900 Printer
My printer is printing in pink color how can i change it to black
Sounds like your black cartridge is either empty or clogged. Take out the black cartridge and press the print head against a moist paper towel. You should see a nice black rectangle, if you don't you could try placing the print head on a wet paper towel for a few minutes to wick out the ink (ink may seep through the paper towel so beware what surface you do this on). If after this there is still no ink flowing, buy a new cartridge.
Dec 18, 2009 | Office Equipment & Supplies
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Mar 04, 2009 | HP LaserJet 4250n Printer
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Jan 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Bob Headrick, MS MVP Printing/Imaging
Sep 16, 2008 | HP DesignJet 450c InkJet Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
326 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
