Question about HP LaserJet 4 plus Printer
PC LOAD LETTER
I CAN
  • chelski Oct 23, 2007
    I CAN PRINT THINGS THAT I HAVE CREATED WITH PUBLISHER BUT IF I TRY TO PRINT ANYTING I HAVE CREATED WITH WORD OR SPREAD SHEETS THE MESSAGE PC LOAD LETTERS FLASHES UP , WHY ?
Check the paper size on Word or Excel - it is probably defalted to Letter - change it to A4 and the problem should go away.
John
Posted on Oct 25, 2007
SOURCE:
Code PC Load A4
This means that the printer is expecting A4 paper rather than letter size or whatever you are trying to use. Check your "Printer Options" on your computer and make sure that the appropriate paper size is selected. A4 is an international standard paper size that is 210 mm (8.27 inches) x 297 mm (11.7 inches) and therefore is just a bit narrower and longer than the American "letter" paper size.
To correct this, cancel the print job currently in the printer's memory, change the computer to the proper paper size, and send the print job again.
Jan 26, 2014 | HP LaserJet 4 plus Printer
How to solve the pc load letter in konica Minolta Printers & copiers?
Is this what it's reporting on its display panel when you try to print? Most likely the paper stop in the drawer has moved or been changed to something other than letter; so the printer thinks it has something other than letter size loaded (probably got moved to A5) The printer "reads" the the drawer stops, it does not "see" the paper it needs.
Oct 04, 2013 | Konica Minolta Office Equipment & Supplies
How do I load information onto the flash drive from my desk top computer?
Plug the flash drive into a USB port. Usually it will take a minute or two to load drivers, and will show up in "My Computer" as an additional hard drive (Maybe E: or F:, or some other letter depending on what drives you may already have). Doubleclick on the drive letter to open the folder and drag documents from folders on your PC to this folder. Or you can save documents directly to the flash drive once it's mounted, by navigating to that sam edrive letter in the "Save As.." dialog box.
Feb 25, 2011 | IBM Computers & Internet
I received message from ifile stating that my resume has been selected, and offer letter has been attached in the website line wwwifile.it/engmvsj. but i cannot down load . kindly help to down load my...
received message from ifile stating that my resume has been selected, and offer letter has been attached in the website line wwwifile.it/engmvsj. but i cannot down load . kindly help to down load my offer letter jkrishnudu
mail jkrishnudu@yahoo.com
Feb 14, 2011 | Computers & Internet
Printer says " PC LOAD LETTER" will not print
Change in printer driver to use paper "A4" not "Letter" format
Jan 30, 2011 | HP LaserJet 4 plus Printer
I got message from TD-hrinfo BAJAJ LIMITED:-Your resume selected by company. your letter has been attached. kindly download letter by link:-yourfilelink.com/get.php?fid=571018
how to download the letter
Sep 09, 2010 | Computers & Internet
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 4Mplus won't print doc & says: PC Load Letter
Pull down front cover and Put a sheet of paper in tray 1 assembly.
Feb 20, 2009 | HP LaserJet 4 plus Printer
Printer problem
Your printer is asking for letter size paper to be put into the main tray. If you have the tray set-up to legal or something else, reset the tray for letter. If you need legal or something else in the main tray, place letter in the manual flip down tray and press the "on-line" button on the printer to bypass the tray selection.
Aug 25, 2008 | HP LaserJet 4 plus Printer
Pc load letter
1-are the guides set correctly?
2-is the sensor flag there? on the bottomof the machine when you take out the tray you should see a piece of plastic hanging and is very loose it is the sensor for the paper, ( although I have seen it work without it !!!!!!)
Aug 21, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
Clive
Clive
Thomas F. Schneider
