Question about HP OfficeJet 7310 All-In-One InkJet Printer
Cannot receive fax
I can send faxes, but cannot receive them. Fax machine rings but will not pickup. Report states poor line quality. Using VOIP. . Changed baud rate to 9600, and turned ECM off..per Brother email. Was using Verizon Voice Wing with no problems, but they are dropping the service. So I went to another service ITP (itpvoip.com). Any suggestions or info would be helpful. Thanks Claude We have a HP Officejet7210 All-in-One, just had Viszon FiOS installed in our home, our fax will send but will not recieve. The line is connected to our home line. Need help???!!!
5 Suggested Answers
SOURCE: How do I change baud rate to 9600 on Epson CX9400Fax?
This fax speed is 33.6 or 33600
You can change settings to 14.4 or 14400 but not to 9.6 or 9600.
Under: Fax Settings you have this choices:
Speed Dial Setup
Scan and print setup
Communication
Header and time
Under Communication:
DRD
ECM - error correction put this one: off
V.34 - this one is for speed: on - 34400; off - 14400
Posted on Aug 19, 2008
rakeshpramod
  • 234 Answers
SOURCE: Sending fax
Iam afraid HP Supports VOIP Services, they always says that we do not assure fax in VOIP Service because it is not analog it is digital they always refer to your service provider
Also you can tried reducing the speed of the fax machine
That is> Press Menu/Setup> then scroll toAdvance Fax setup> Then Fax Speed> then Press Ok> And reduce the speed to Slow and then try.
Good Luck
Posted on Aug 28, 2008
  • 105 Answers
SOURCE: Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Posted on Oct 05, 2008
  • 44 Answers
SOURCE: Need to change Baude rate of HP 4215 all-in-one mechine
That might help. Faxing is signal timing specific. I believe they are sent from the factory to run at "fast" which is 33.6kbps. Try to set it to medium first (14.4) if no luck set to Slow (9.6). Try these steps:
  1. Press Setup .
  2. Select Advanced Fax Setup .
  3. Press OK .
  4. Select Fax Speed .
  5. Press OK .
  6. Select Medium .
  7. Press OK .
Posted on Nov 13, 2008
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Can't Send or Receive Faxes from MFC-7820 N
You may not need a separate fax line from Vonage. If you don't need a dedicated fax line, you can try changing the "Bandwidth Saver" settings on your Vonage voice line from your account on the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
If your fax machine has a Telephone Answering Device (TAD) setting, you can share your voice line with your fax machine and be able to receive faxes and voice messages. Hopefully this will work for you.
Dave Grannas
Nov 04, 2008 | Brother MFC-7820N Printer
Poor Quality
If you can copy ok you have effectively ruled out your machine as you have used both the scanning and printing mechanism of the machine.
It will probably be the fax on the other end as if it sends a poor quality page that's all your machine can receive, a poor line can also cause problems if it is from multiple faxes. If so have your provider check the line (you probably hear static on the line).
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother Printer Fax Machine
The connecting depends on several issues. This cant be said within a few words.
You have to read the manual which explains the very diffrent setting (see chap. fax). You can download the manual here:
www.brother.com (choose your country from landscape, choose your country, choose download&support)
Have a look at the faq, too.
If that doesnt help, plz call brother hotline of your country!
Jan 11, 2008 | Brother Multi-Function Center MFC-240C...
Trouble shooting
Hi my mom has a brother fax machine. When printing it puts a vertical line straight down the middle. It takes the carbon paper and I noticed underneath there is a black nob thing that sticks up and that is whats making this line why and what to do? Thanks vicky
Nov 12, 2007 | Office Equipment & Supplies
"poor line condition'
This is a problem with your voice over ip service. You have to change the setting on your fax machine for example the Baud speed down to 9600, the ECM= off, and the Oversea settings on. Make sure your VoiP ATA is the first thing after your modem or whatever connection you are using for the internet. If you using and old model fax 95% of the time it will not work with VoIP service.
Jun 12, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
HP OfficeJet 7310 All-In-One InkJet Printer Logo
548 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
