Question about Nokia 3110 Cellular Phone
Phone dead i switched off my 3110 nokia for charging. later when i put it on, it won't switch on anymore but it shows on screen the phone is charging. pls help.
    Problem Solver:
  • 16 Answers
Have you tried removing the battery for 5 mins, then re-insert and hold the power button for 10 seconds
Posted on Jun 01, 2009
My NOKIA 3110c phone got switched off by itself and has not come alive. If I try to switch it on, the screen blinks white thrice and then goes dead again!
Firstly, Remove Sim Card , Memory Card and try to reboot 3-6 times,sometimes this trick is working.Even if the problem still persist better to contact mobile repairing shop or follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 23, 2011 | Nokia 3110 Cellular Phone
My nokia 3110 classic is dead , how will on
PHONE IS DEAD WON'T COME ON
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
You can also try out another battery..ok
GOOD LUCK.
May 28, 2011 | Nokia 3110 Cellular Phone
My nokia 3110 dead not power
FIRST CHANGE UR BATTERY WITH FULL VOLTAGE
VOLTAGE 3.60 - 4.20V.
CHK BATTERY CONNECTOR
IF IT DESOLD
SO SOLD{RESOLD}IT
CHK SHORTING ON BATTERY CONNECTOR ON BUZZER RANGE IN MULTIMETER
CHECK CHARGING IN UR CELL
CHK ON OFF SWITCH VOLTSGE 2.80V
CHK ON SOFTWARE OR FLASH UR PHONE
SAME IT DEAD
SOIT HARDWARE FAULT
CHK ALL POWER SUPPLY
IDRISH 911
Oct 30, 2010 | Nokia 3110 Cellular Phone
Phone dead
make sure the battery is in the right way. the sim is in right. the battery is charged... you may have over charged your battery
Jun 02, 2009 | Nokia 3110 Cellular Phone
Ringtones does not sound
nokia 3110 on- off not switch not working working
but charging show on the screen
what fault?
Dec 03, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
167 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
