Question about Behringer F-CONTROL AUDIO FCA202 External Sound System
Not working I have recently bought the fca202. The problem is I can here the MIDI playback through it but the input doesn't work when I plug my guitar into it. And i can't here anything when I plug it in.I am using cubase studio 4 on Vista. Please can you help?
  • 4 more comments
  • aaronkg1 Oct 23, 2007
    Hi i managed to get the input working. However after an hour of recording a message popped up saying a serious problem has accoured please restart cubase. So I restarted cubase and no device could be found so I tried to re-select the fca202 as my vst audio system and a message came up saying The ASIO driver FCA202 ASIO DriverFCA202 ASIO could not be initialized! Do you know what any of this means?
  • Anonymous Nov 16, 2007
    same problem how do you solve this?
  • Anonymous Apr 05, 2008
    cannot get f control to work with Vista
  • emmefa Apr 24, 2008
    I am using live lite and it keeps telling me that ASIO driver is unable to be opened. Eveything is correctly connected, installed. Even worked in demo mode which is not useful. Please advise....
  • Anonymous Jul 31, 2008
    there is sound at start up, and then i run bpm studio about 5 minutes and then i close the program and run it again, and the sound is vanishing
  • Anonymous Mar 26, 2009
    Same deal, I can get playback through it but not from the line in. However I can record it and play it later, I cant hear it wile I play, only the audio coming from my Vista Laptop.. .HELP!
    Novelist:
    Champion:
  • 382 Answers
Http://forum.cakewalk.com/printable.asp?m=745403
Posted on Nov 10, 2007
SOURCE:
Alesis io2 guitar inpu and mute playback for backing track in audacity
Audacity is a copyrighted audio source and does not permit you to record tracks or playback of any kind. you will need to D/L the audio file you are trying to record in tangent and then play them together through an audio remixing app, like Ableton live or FL Studio
Jan 28, 2014 | Alesis iO 26 Sound Card
I have IonAudio Discover Guitar. I am a Mac user, 10.6.8, MacPro 3GHz Xeon Dual Core with 6 GB RAM. The instructions say I should create an Aggregate MIDI Device under Audio MIDI Setup with the following...
Have you tried the guitar in another Mac/ PC? If it still doesn't appear, there may be a problem with the guitar electronics. If you bought it new, take it back to the shop/ send back to the vendor.
Sep 10, 2011 | ION Audio ION DISCOVER GUITAR USB
Hi, Ghost midi pickup on MF guitar : Midi volume wiill not increase progressively. Look at data input in computer : controler 7 data from 0 to 15 = no sound then at 16 sound will be audible but already...
The first thing is to verify the pot you are using has the correct taper... there are several types and the nomenclature is NOT too consistent. The second thing is to measure the voltage out of the pot to make sure it covers the range between the outside terminals. After that measure the voltage across the pot... I suspect it might be 5 volts... if you find it way below that, that would certainly be the problem. Note: I do not have schematics for this product and my comments here are based upon my engineering experience and how this sytem is likely to work. The MIDI convertor MAY use a PIC processor or similar.
Dec 03, 2010 | Graph Tech ghost Acoustic MIDI System -...
Get sound through a Behringer 1204FX mixer & FCA202 interface
Block diagram available here:
http://www.behringerdownload.de/XENYX_GRP2/1204FX_VIEW_Rev_A.pdf
Where are the trim controls set?
Those mics use both phantom and battery power; are the mic switches set to phantom?
Try using the CD/Tape outputs to the FCA202
Nov 20, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
Audio Inputs suddenly producing buzz/broken
The UA 25 needs a GOOD quality USB cable, the thicker the better. Cable loss means that by the time the 5V power supply from the computer reaches your Edirol, the voltage has dropped to about 4V, which then has to be boosted back up to 5 Volts and inverted to -5V.
Cheap cables will hamper performance or prevent it working at all ( I lost 2 hours once with this problme ) . Also avoid using the FRONT USB connectors on PCs, use the connectors that plug direct into the MOBO on the rear of the chasis.
Good luck
Dec 22, 2007 | Edirol UA-25 External Sound System
Midi problem
My dear friend I also have the same problem (i am using an us-122) but i still have the same problem). I am searching and searching for days and nights to solve this. If you find any solution please send me an e-mail on: night_conformer@hotmail.com Thank you very much.
Dec 18, 2007 | Tascam US-144 Sound Card
Hi need sound
Certain early models of the Sound Blaster cannot do both MIDI input and wave (audio) output at the same time. Thus, if you've selected "Creative Labs" as a MIDI In device in Cakewalk’s Options | MIDI Devices dialog, wave audio output won't work. Note that MIDI output will work fine along with wave audio output: you can select Creative Labs from the list of MIDI Out devices. The problem occurs only when you've selected the Creative Labs MIDI In device.
Hope that helps!
Dec 08, 2007 | Cakewalk Guitar Tracks Pro 2 Classic
Low audio input
You need to use a mic preamp or a mixer with a mic preamp built in. The inputs on the FCA202 are line level and they won't work with a mic directly.
Dec 02, 2007 | Behringer F-CONTROL AUDIO FCA202 External...
Behringer F-CONTROL AUDIO FCA202 External Sound System Logo
313 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
