Question about Refrigerators
I have a Kenmore side-by-side frig which I was told was mfg by Whirpool: Model 106.51264104 Mfg April 2003 It stopped cooling on both sides. A repr tech replaced "RELAY CAPASITOR ASSY." I now get freezer temp of 5 deg +/- but frig side has temp of 34 to 40 deg at bottom but only 42-50 on upper shelves. Reprman was beach twice but can't find any other parts that need repr or replacement. Freeon Ckd/Ok. It is not overly packed with bottles, etc.
    Brigadier General:
  • 3,917 Answers
Okay if not the coils inside the freezer section behind the panel that covers the coils is where the ice is located? I don't know of any other coils inside the freezer? Did you confirm that compressor itself is running? Not just the fan and clarify again the location of the ice.If you have frost on the freezer coil, you probably have a defrost problem. Your freezer should go into a defrost cycle about twice a day. When this happens the compressor and fans shut off and a defrost heater in the freezer coil will turn on heating away the ice. This usually last 10 - 20 minutes. If the defrost coil doesn't defrost it will become a solid block of ice and this will inturn block the air from blowing into your refrigerator compartment. There are several things that can go wrong with the defrost cycle such as the defrost timer, defrost heater, or the defrost termination thermostat.After defrosting the coils with a hair dryer, they have not frozen up again in several days. I did notice that the air diffuser in the refrigerator side does not seem to open by itself. It is not broken physically. If I open the luevers manually, eventually they will close and not reopen.
OR
Relays will burn out for the same reason a light buld burns out. So many hours of life and they go. Also a power surge from a storm can cause them to go.
If the compressor is cold try a relay. If you hear the compressor click on and then click off after 3-5 seconds try a relay.
Thank You
Posted on Jun 01, 2009
Not cooling
condenser must be burnt
Jan 19, 2012 | Kenmore Side by Side Refrigerator
My older model kenmore side by side refrig. is not getting the frig or the freezer cold model#9545510 serial #SD4123102 mfg. date 10/94 please help is there something i can try first before getting a...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 17, 2011 | Refrigerators
Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Jun 18, 2010 | Ruud Central System Air Conditioner
Fresh side not cooling
I will assume until you can confirm the model number is near Sears KENMORE ELITE, Model No. 10650594000 But I will need you to double check because Sears always uses a number different than the MFG.
For the moment I need you to remove some things from the freezer and remove the back panel covering the evaporator coils. Look for the coils to be frozen over. If so it could be the adaptive defrost control found inside the fresh food compartment part number 4388932
Or a problem with defrost thermostat or the defrost element. I am here to help, Just let me know, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
May 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Frig does not stay cold enough
you are either low on coolant or the fan inside the freezer compartment is stuck or defective.
Mar 25, 2009 | Kenmore 55203 Side by Side Refrigerator
Quit, but has power 106.56563400
is the compressor hot? if yes, unplug , let it cool, and replace relay assy.
Oct 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Water Leak
my frig start giving noise but it was very little noise i had not check where from noise is coming then the noise was increasing more , since last week its stop working,let me know problem.
Sep 22, 2008 | Kenmore 53092 / 53094 Side by Side...
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
