Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
No picture, humming
Had tech come look this morning, said need color wheel, ballest and power supply, wondering what one has to do with other. what happen is watching tv big pop, no picture now when turned on loud humming noise and will come on off by itself. tv is samsung hlp6163wx/xaa
    Champion:
  • 205 Answers
Lost the lamp, replace lamp
Posted on Jul 07, 2009
After about 30-60 minutes TV starts to hum and picture gets distorted, could this be the color wheel...???
Sounds like a sync problem due to color wheel speed. clean and lubricate color wheel motor with tiny amount of Z-Max lubricant (liquid Buckey balls, available at Wal-Mart), on each bearing. make sure wheel is free-wheeling and turns easily. Should cure problem. If the color wheel is in good shape, there is a power supply problem, which may be due to dried out electrolytic capacitors or a regulator that's failing. Troubleshooting or controller board replacement may be needed. Regards.
Dec 07, 2015 | Mitsubishi WD-73840 73" 3D Home Cinema...
I have a samsung model #HL-R4266W tv, It is making a humming sound, and has no color other than it being in black and white the picture looks fine, what could be the problem?
This tv design have a colors wheel in it,have humming sound or loud motor noises.The colors flashes Black&White or lost all colors.The colors wheel is dying and the causes.The colors wheel replacement are not a do it ur self project.Hire a tv Tech. to do it right the first time.Colors wheel sit way back close to the Light Projection Engine itself.
Dec 30, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
TV will not come on. Tries to start, no pic, then shuts itself off. Humming sound like fan runs for a while and then stops.
This tv have a colors wheel is dead,require a new colors wheel replacement.Tv humming,loud squiling or motor noises and picture flashes black&white within the picture.The problems is the colors wheel are worn out or warp and it not spinning correctly in it motor joints anymore,it is the tv causes.Call the tv repair shop for a tech. to repair and replacement of the colors wheel.This job,it not simple,must take out alots of machanicals parts,even come to the colors wheel itself to replace it.
Nov 26, 2010 | Samsung HL-S4266W 42" HDTV
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
I have a 50" Samsung DLP about 6 years old. Like seagoat, My set is making a "buzzing/humming" sound. Just before it did that I heard a single "pop" sound. For the past week or so the picture has been...
Tv have a colors wheel,hearing a humming or buzzing noises or black&white picture flashes with the picture,the colors wheel is dead.Hire a tv tech. to replaced the colors wheel,it pretty hard to replaced the colors wheel,because have to have take out alots of machanical parts,before even can come to the colors wheel itself to replace it.
Oct 25, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Started making a humming or vibrating sound, and the color and resolution went bad at the same time. Now when I attempt to turn it on, I get the same vibration sound and nothing else.
This tv have a colors wheel,it dead.Require changing.Humming or vibrating sound,Flashes pictures black&white.The colors wheel is dead and it not spinning in it axis motor correctly anymore.Hire a tv Tech. to change the colors wheel,it very hard to change the colors wheel.Because u have to take out many machanical parts,even before u can get to the colors wheel itself.
Oct 14, 2010 | Samsung HL-R5656W 56" DLP HDTV
Black and wight picture
The tv have a colors wheel.The tv make humming,buzzing motor loud noises or flickering black and white pictures.The colors wheel is dead,require changing,bcause of the colors wheel axsis rubbing on it sides or worn out,than have black & white pictures.Hire a tv tech, to do the job.Because changing the colors wheel is not easy.Require take out many machanicals parts,before even can change the colors wheel it self.
Sep 01, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
470 people viewed this question
Jerry Greenberg
Jerry Greenberg
