Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Whirlpool door lock error
Getting error on Whirlpool Duet front load washer dL F. Doors won't lock. I got it to lock manually using a screwdriver and tested starting the washer. It did but now it won't unlock and I can't close the door. Looks like the lock mechanism is broken? How much would a service repair cost just to fix the door lock? I wanted to change the side that it opens from anyways. Will getting the door open side kit fix the problem as well for about the same amount?
  • 1,869 Answers
Turn off all water to your washer run the washer empty for a full cycle when the cycle ends the door will release
spray a lubricant such a WD40 into/onto the door lock
the door kit will not fix the problem
Posted on Jun 01, 2009
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
E dl and the door will not open
F/dL error - Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
If all the connections are good replace the CCU.
This is a very common problem with Whirlpool duet front-loading washers and additional details you can find in this link: Whirpool DL_F_Code
Hope this helps (remember to rate this answer).
Aug 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control panel displaying DL F and not starting
The door locking routine fails to lock the door after six attempts the the error code FdL flashes to indicate a failure in the door lock and switch assembly. The only viable solution is replacing the door lock and switch assembly. Click on the link below for the instructions in replacing the door lock and switch assembly.
Replacing the Door Lock and Switch Assembly on Whirlpool Duet Front-Load Washers
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting fdl error message, when I try to start load, door is not locking
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Aug 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door locked error code dL/F
If your door is already locked and you get an "F" error press and hold the cancel button, and select drain/spin. If this still doesn't work and your clothes are trapped inside do not resort to getting out the crow bar and a sledge hammer. (Though you may really feel like doing just that). You can manually unlock the door by following these steps:
- Unplug washer or disconnect power.
- Remove the lower kick panel.
- Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
- Located on the bottom of the door switch/lock unit is a teardrop shaped tab.
- Gently pull the tab down about a 1/4˝ or until a click is heard.
- The door may be now opened.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Check page 46 and 51 in tha manual given in the above link
May 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer front load and its giving me a message of dl f. I can hear it trying to click but nothing happens.
This should indicate a door lock error and the clicking is the door trying to lock. The door is supposed to attempt to lock six times before the dl error is displayed. It is most likely caused by a faulty door lock switch. Hope this helped and best wishes.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool ht duet still getting F dl error
DL= Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
Potential Causes
if you have done all the abovet the CCU must be bad
Aug 28, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
door 6 times before displaying the error.
Potential Causes
Control Unit (CCU)
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
456 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
