Question about Insignia NS-DV2G MP3 Player
Database full, delete content or re-format device
I got a Mac computer (been using a pc). I plugged my MP3 up to charge, then went to the gym. I tried to listen to the songs I had loaded and nothing was there. The message "database full, delete content or re-format device" is posted. I can't even listen to the TV's at the gym. How can I fix this?
    Problem Solver:
  • 5 Answers
You should format your mp3 and try again.in this way the errors on mp3 player will be removed.
Posted on Jun 01, 2009
Hello, the problem that I have with my SanDisk 2 GB MP3 player is that now, whenever I try to put songs on it, I get a message that "the device has stopped responding" or "the device does...
Try and reset the player first, If this does not fix the problem, Click this link to down load the Sandisk updater program to run a firmware update...Updater... Resetting the device: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Next time you need to delete files heres how. --
There are two ways to delete files on your Sansa player. You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device 1. In playback mode, press the Submenu button. 2. Select Delete.
METHOD 2 - Delete files using a PC For all other Sansa players: 1. Connect your device to the PC. 2. Select Open device to view files using Windows Explorer on initial connection. 3. Locate the folder where your files are stored. 4. Click to select the files you want deleted and delete the files.
NOTE: If songs still exist after deleting, you may need to switch USB modes from MTP to MSC or vice versa. See this tip HERE
Capacity issue This error occurs when a Sansa player is almost filled to capacity. A Sansa player can NOT be filled to full capacity. (i.e. you can't put 2GB worth of songs into a 2GB player)
The player needs the extra capacity to create and maintain a "database", a database holds all the information such as playlists, recordings, song information, etc. The larger the amount of songs, the larger the database gets.
To resolve this capacity issue, you have to delete contents on your Sansa player using a PC.
STEP 1 - Delete files on your player 1. See first note on how to delete files on your Sansa player using a PC.
FAT corruption This error also occurs when there's a file system corruption in your Sansa player.
To resolve this issue, run error-checking to fix errors in your device using a PC
STEP 1 - Connect the Sansa player to the PC in MSC mode
STEP 2 - Run Error-checking to check and fix errors 1. Double-click on My Computer (Computer for Windows Vista). 2. Right-click on the drive letter associated with your Sansa player and select Properties. 3. Click the Tools tab and select Check Now. 4. Click both check boxes under Check disk options. 5. Click Start
If an error occurs while plugging in the player to the PC and some files are missing in the player, the database might be corrupted. To resolve this, you will need to format your player.
NOTE: Formatting will delete all files in the device. Your data (music, photos etc) is NOT recoverable.
Nov 16, 2010 | SanDisk Sansa e260 MP3 Player
DATABASE FULL DELETE CONTENT OR RE-FORMAT DIVICE
Start pilot with SD card installed. It should boot to SD card files. Go to settings and format internal drive. Be sure player is fully charged.
Oct 25, 2010 | Insignia Pilot MP3 Player
Database full delete content or re-format device
I GUESS THAT YOU WANT TO FORMAT THE DEVICE OR ERASE IT''S CONTENT.
FOLLOW THE STEP BELOW TO PERFORM A FULL FORMAT:
1. RIGHT CLICK THE MY COMPUTER ICON AND CLICK MANAGE.
2. A WINDOW COMPUTER MANAGEMENT WILL APPEAR.
3. IN THE LEFT COLUMN CLICK DISK MANAGEMENT.
4. ALL THE ACTIVE DRIVE WILL APPEAR IN THE TABLE UP AND DOWN TABLE.
5. YOU CAN RIGHT CLICK DELETE THE PARTITION OR FORMAT ACCORDING TO YOUR NEED
OK
HOPE THIS WILL HELP YOU
GOOD LUCK.........
UTTAM
Jan 24, 2010 | Insignia NS-DV2G MP3 Player
Insignia 2gb video mp3 says DATABASE FULL DELETE CONTENT or RE-FORMAT DEVICE
Hey ! This happened to me when I took my MP3 off of my Mac. I didn't know why ,but I sensed a pattern. Thats when I figured it out. All you have to do to prevent this is "Safely Eject" your hardware from your computer whenever you are done placing things on/ taking things off of it from your computer. For a Mac, all you do is drag the Icon thats on the desktop to the Trash, and it will eject it, and for Windows, you go o the bottom right hand corner of your screen and find the "Safely Eject" icon, click it, and then click what you want to eject.
Now, if you have already done the action and that message pops up, this is how you fix it.
Go on your computer and plug in your MP3. The files will still be on there, but they won't show up on your MP3. They will show up on your computer. Make an empty, easily accessible folder somewhere (I always put it on my desktop, its not going to be there long). Then, drag all the files from your MP3 to that folder (the ones you want to keep, anyway). After its done copying the files over, safely eject your MP3 from your computer.
Now, go on your Insignia and find where it says "Empty Internal Memory". Click that, and then click yes. It will now empty all the memory from your MP3. Then, find where it says "Restore Settings" or "Restore Default Settings". Click that. Now, you basically have a brand new MP3. No kinks to it.
Now, plug your MP3 back into your computer. The tricky part is when you delete all the internal memory, you also delete some of the folders that actually come with the MP3, namely the "Music" folder. Thats what took me a while to figure out. To regain your "Music" folder, all you have to do is go into the folder named "AUDIBLE" (all caps, hopefully), and then create a folder named "Music" (just type it like that, not "MUSIC" or "music"). After you have that down, you could drag all your music back from that folder you made a little while back. Now you have all your files on your MP3 again! After you're sure its done copying all the files back to your MP3, make sure you SAFELY EJECT the MP3 from your computer. Check that 3 times before you do it, just so you don't have to repeat this tedious process.
And, presto, you're done! At least thats how it worked for me and a few others :D
Hope it helps!!!
- Brandon
May 06, 2009 | Audio Players & Recorders
My mp3 player says that the memory is full but I have no songs
if you are deleted the song using computer interface before, it is still on hidden file. plugin your device to computer and go to your sansa directory,
unhide all hidden file and delete it if you are using windows, but for mac pc, just go to the finder then ampty the trash.
Mar 02, 2009 | SanDisk Sansa e260 MP3 Player
Iriver X20 database full
does the message stop you from using the iriver?
if it doesn't then there's a format function on the iriver in the settings menu...
if it does then there may be a problem with the usb connection...
either the iriver isnt responding or the computer can't read it!
for the user below there is most likely a format will fix it...
Aug 01, 2008 | iRiver X20 MP3 Player
Database full ns-2v17b
Your database is corrupt
You have two choices here:
1) Delete the songs
2) Reformat the player
The player isn't trying to BS you
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 11, 2008 | Insignia NS-DV2G MP3 Player
Not enough room for music database please free 4 mb
The device needs at least 4MB of free space.
You need to keep deleting files until there is 4MB less than the total capacity of the device.
Its not syncing because the device is too full.
If removing the 4MB doesnt work. Try formatting the device thru My Computer>Device Name (m200)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
Nov 20, 2007 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Cannot load the music Data base.
Music Database refers to the information you see on the screen (i.e. Artist, Album, etc.) The device needs some free space in order to create this list.
The device is either too full, or the database is corrupt.
First, try connecting to your PC and deleting about 10 to 15 tracks. Restart the device and see if that helps.
If not, Try formatting the device thru My Computer>Device name (U10)>Right Click and select format.(this will erase everything on the device)
Best of Luck.
Nov 03, 2007 | iRiver U10 Digital Media Player
Deleting tracks
You may have a memory allocation error. You can "format" the device thru My Computer, that should resolve it. Go to My Computer>Device name, right click and select format. This will delete all contents. Best of Luck.
Sep 16, 2007 | Creative Labs Zen Nano Plus MP3 Player
Insignia NS-DV2G MP3 Player Logo
132 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
