Question about Toshiba DKT2010SD Phone
Phone Line A 4th phone line was added to the office I work in and since then the conference room phone will not work. The display screen says: PROGRAM = 39 and doesn't have a dial tone.
  • 2,005 Answers
Your phone is exceeding it's ring equivalent rating
(power rating for all phones on the circuit line)
contact you carrier for a line booster
Posted on Jun 01, 2009
Can I change the ring tone for just one of the lines on my nortel norstar phone m7324?
If your phone system has 6.1 software or up then yes,the tech or vendor can program it for you. If you know how to program look under Config/Lines for Ring Type.
Oct 17, 2012 | Nortel M7324 Refurbished Norstar System...
Setting the date and time
After selecting 1, type in the date mm/dd/yy (it doesn't appear on the screen) then press hold/save. Then type in the time again it won't appear on the screen press hold/save. It will then return to the main screen with the correct time and date. Hope this helps.
Oct 16, 2012 | LG Ericsson LIP-8012D 12 Button IP Phone
Are conference tables and dining room tables interchangeable?
I definitely suggest using your conference room table as adining room table because all you need to do is put some placemats and acenterpiece and it morphs into a dining table. I'm not sure that I'd recommend using your dining room table as aconference table because it might look out of place in an office. Also, conference tables tend to have holes inthe center for cords or phones to be plugged in to.
May 29, 2012 | Furniture
I have Nortel Polycom 2033 IP conference unit. When we have a conference, it's really bad sound quality. Is there anything that i can do? Thanks.
has it always been like that or it just started. this can be a speaker gone bad or an unstable line. a simple service may correct that effectively.
Jul 27, 2011 | Nortel Audio Conference Phone 2033...
I can not get a dial tone on our new soundstation 2W I have unhooked one of our phone lines in our office so the line is good but does not work on the soundstation but works on our phone. When you try...
You need to update the software on the device. I called their support line and the tech explained everything. This has been a common problem with this conference phone.
Feb 07, 2011 | Polycom SoundStation 2W (2200-07800-001)...
Avaya 4690 just flashes red lights and makes a click sound when booting....over and over again Nothing shows on the screen. Was working fine, just moved it from one office to another... now will not boot
This usually means the phone is not receiving enough power. You either have a power issue in the electrical of the new room or the power adapter is not functioning correctly. Try plugging the phone back into the old office to see if it comes up correctly, if it does their is some sort of issue with the electrical supply in the new room. If you have another conference phone try using that power adapter on the non-working phone.
Dec 14, 2010 | Avaya 4690IP Audio Conference
Problem adding additional lines to calls
To "jump on" you would need to turn on executive override. Its in Program 30,31,35 in system programming. To conference call simply press Conf/Trn call the extension to conference in with. Have them pick up handest and press Conf/Trn again and you are all connected. More info and your manual can be found here.
http://guides.idacomusa.com/
Jun 11, 2009 | Toshiba DKT2010SD Phone
Toshiba DKT2010SD Phone Logo
102 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
