Question about Toro Lawn Mower With Toro Power Tools
Mower will not move
The mower runs great, but it will not move in any gear, nor will the wheels turn even when the it's in the neutral position. Had a new drive belt put on and the repair person said he could not find any thing else wrong with it. I took it home and mowed with for about 15 minutes and it froze up again. need help in plain city. Thanks Larry
email-lbrown55@columbus.rr,com
    Brigadier General:
  • 3,917 Answers
As you understand there are serveral reasons for this behaviour. ......Oil has run into the cylinder.
The Engine Safety Brake is not disengaging an is keeping the motor from turning clean the spark plug and the airfilter.........then go for it!! Pull the plug out and check for oil. when you had it on its side maybe some oil got into the cylinder. If so you need to drain this out and clean the plug. Let it set for a day and try again. Or try pulling the cord with the plug removed to see what comes out. Just recheck your oil level prior to starting.Always, when getting under the deck, raise the mower so the plug is skyward. If you do this, you will not get the oil accumulation in the cylinder and air cleaner... Makes a real mess when it takes off, and plugs up your air cleaner
If its still locked up.. and you've made sure the cylinder is free of any oil....., make sure the flywheel brake (its let go when you hold the handle down) is actually letting go of the flywheel. Take the shroud off (4 bolts) to get a good look at it.
Thank You
Posted on Jun 01, 2009
Husqvarna 4623 zero turn mower will not move
Maintanance - How to purge Hydraulic drive system Published 01/13/2010 11:56 AM ' Updated 06/02/2015 02:52 PM
How do I purge the hydraulic system?
Hydrostatic transmissions use oil, under pressure, to provide movement for the tractor. The fluid is pressurized with a pump inside the transmission. If any air is in the fluid, the pump will try to pressurize air. This condition is known as cavitation, and is detrimental to the pump since it allows the pump top operate dry. When the pump cavitates it is not pressurizing any fluid, so the transmission is not able to provide the movement needed.
If your mower is new, or has been stored for a long period (longer than 2 months) the transmission needs to be purged before use. Also, if you experience loss of drive, or slower response, then the transmission should be purged first.
The following procedure will remove trapped air inside the transmission(s).
IMPORTANT: SHOULD YOUR TRANSMISSION REQUIRE REMOVAL FOR SERVICE OR REPLACEMENT, IT SHOULD BE PURGED AFTER REINSTALLATION BEFORE OPERATING THE TRACTOR.
Step 1- Place the rear of the mower safely onto jackstands on a level surface with engine off and parking brake set.
Step 2- Disengage transmission by placing freewheel control, located at the back of the frame, in the freewheeling position.
2a- Mowers with seperate pumps and wheel motors the freewheel is activated by turnign the bypass valves, one on each pump, two full turns.
The oil resevoir needs to be filled to the specifications listed in the owners manual before starting the purge procedure.
Step 3- Sitting in the operators seat(riders), start engine. After the engine is running, move throttle control to slow position. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 4-Move motion control levers to full forward position and hold for five (5) seconds. Move levers to full reverse position and hold for five (5) seconds. Repeat this procedure three (3) times.
NOTE: During this procedure there may be some movement of the drive wheels, but they are not under load. The air is being removed from hydraulic drive system.
Step 5-Move motion control levers to neutral (N) position. Shutoff engine and set parking brake. Check and add oil as needed for units with an oil resevoir.
Step 6-Engage transmission by placing freewheel control into driving position, or by closing the bypass valves on the pumps.
Step 7-Sitting in the operators seat, start engine. After the engine is running, move throttle control to full speed. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 8-Slowly move motion control levers forward, after the tractor moves approximately five (5) feet, slowly move motion control levers to reverse position.
After the mower moves approximately five (5) feet return the motion control levers to the neutral (N) position. Repeat this procedure with the motion control levers three (3) times.
Step 9-Your mower is now purged and now ready for normal operation.For further information or assistance, we recommend contacting your lo
Aug 06, 2016 | Husqvarna Garden
Why won't the mower move forward or backward even though the engine is running and the blade will engage?
First off, riding mowers do not "go into gear"; nor can they be shifted into or out of gear...nor, as a matter of fact are they "automatic" or do they have "automatic" transmissions. Instead, the so-called hydrostatic "transmission" is nothing more than the sense one gets--encouraged by mfr/seller misdirection (or product ignorance)--that a mower works just like a car...rather than being powered by nothing more than a belt that turns a wee little hydraulic motor, the speed and direction of which is controlled by the foot pedal controlling volume of fluid coursing though it to hydraulically drive the drive wheels.
If your rider will not move, that means one of two things (other than fatal failure mode)...or rather two of one thing, the latter being that hydraulic fluid it not flowing, is not pumping freely, through that motor.
Reason 1 (the more likely) is that the manual-mower-push switch on the motor has been engaged to permit the mower to be pushed without the vehicle (drive wheels) being blocked...because the engine is not running, so the fluid cannot flow with the turning of the drive wheels (unless the switch is engaged).
Think of it this way. When the mower is running and the clutched engine PTO is driving the belt or shaft that drives the hydraulic motor, the direction is chosen by reversing direction of fluid flow that the motor is circulating under pressure (also called pumping) to the drive wheels. Push toe and it flows and drives wheels in the mower-forward-drive direction; push heel and it flows the other way. Now, what about when neither is pushed? Then, essentially, all channels of flow are blocked--"neutral" (if you want to think of it that way) is not freewheeling (as with a car), it is drive wheel blocked by hydraulic lock at the motor. That is why a "hydo..." equipped mower does not coast as does a car. Alternatively, suppose that you could lift up and try to rotate the drive wheels in a particular direction. You would find that the wheels resist turning (unlike rotating RWD car drive wheels to remove a drive shaft, for example)...because they are essentially hydraulically locked by the motor that is not allowing compensatory fluid circulation in any direction!
Now, to disable the manual push mode that allows the drive wheels to rotate for manual pushing, look under the mower at the drive motor. It will be at the end of the belt loop or shaft being driven at the PTO beneath the engine. Now, find some kind of protruding lever big enough to grasp. If it seems "up" push it down; if "down" push it up...just make it go the other way to release. Now, start up and drive the mower normally. But wait! Before you mow, read the below.
Reason number 2 for unexpected drive wheel drive failure is absence of fluid to drive them....because you have not check fluid level and maintained it as the instructions directed you to do. So find the fluid plenum/level-check container and add some fluid if it is low. Just a little. Then start the engine and check lever with motor running. Fill carefully to indicated level but be very careful not to over fill. The mower should now run with valuable maintenance lesson learned. And remember that neglected fluid check can greatly shorten hydraulic motor life. Oh, make sure to check fluid level again when finished....after any air has been purged...add if/as necessary.
Nov 10, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
How do you push a toro riding mower
riding mowers have a bypass system to be able to move a machine that's not running. At the rear of unit you will find a heavy wire coming out the back end lift a little and pull this out. you should now be able to push unit
Oct 18, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Why one wheel turns and other won't
Sounds like a seized bearing. Shoot oil into it or remove wheel and you can tell that way. I would oil the shaft and wheel well before taking apart.
Sep 20, 2014 | Great States 18-Inch Deluxe Reel Mower
New mower McCulloch riding mower won't start after ruuning in reversenew mower
Take a look at your switch..you most likely have a third position switch..meaning a off start position and back to run.after starting...but a middle position between start and run is added not to allow to run or start in reverse you must manually move the switch to the middle..or put the gears in neutral...if not that one of the safety switches is not functioning right..new so warranty should fix that..good luck.
Apr 29, 2014 | Briggs & Stratton Garden
My riding mower will not shift out of neutral
When you try and put it in gear, what happens? any noise? can you feel it in the shifter that it is going into position? Raise up one side of the backend, leaving 1 wheel still on the ground, engine off, put into gear and turn the wheel you have in the air. Does it move? if so, does the pulley on top turn? If it will not turn, remove the belt and try again, if it turns with the belt off, you have a belt issue meaning it could be belt, springs or pulley issues. If you try all of this and the wheel turns but the pulley does not then I hate to tell you but you need to hunt down another rear..Let me know what you find and I will try my best to help you through figuring out for sure..Best of luck..
Apr 06, 2014 | Murray Garden
Lawn mower will start, but won't move????
If you have had either of the rear wheels off, remove the cover from the center and observe the shaft with the engine running and transmission in gear. If the shaft is turning, you have lost the 1/4 inch key that locks the axle to the wheel to make it go
Sep 11, 2009 | Garden
Mower will run will not go foreward or backward
With transmission in neutral...start the engine and move the speed lever to highest speed and move it back to brake position, then shift the transmission into gear and move speed lever, this will fix the problem.
Apr 26, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
22 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
