Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door does not function makes couple of buzzing sounds only
My garage door does not open makes 2 buzzing sounds as if its attempting to open; the green light at the overhead flickers at the same time and then it quits with no action This is Chamberlain Lift Master 1/3 hp garage door opener. Please help Thanks!
  • jshamim Jun 02, 2009
    How will it look like? What should I do if it is stripped?
    Thanks
    President:
  • 3,197 Answers
Remove the cover and check out the drive gear. It is white nylon and is probably stripped.
Posted on Jun 01, 2009
  • Don Maggard Jun 02, 2009
    The teeth will be worn off and you normally see what looks like white sawdust on the cover you remove.
My craftsman garage door opener is beeping (2 hours). How can I stop it
Our garage door opener has a safety beam across the floor which prevents the door from closing on objects which are sitting there. This safety feature also makes an annoying beeping sound each time the beam is crossed. This tutorial will show you how to disable the beep, but still keep beam functional. https://www.youtube.com/watch?v=Cn_vGe_7_x4
Jul 14, 2016 | Sears Craftsman LiftMaster Chamberlain...
Overhead Garage Door Opener
Sounds like the motor has failed. Clicks is the solenoid, buzzing is the windings on the motor trying to move. You can check if the motor turns by hand, and if it does, you need a repair person.
Jun 16, 2016 | Building Materials
It takes 4 or 5 attempts to open first 2 or 3 times it opens a couple of inches then closes light on control flashes red then 2 amber back to red then on about the 3 or 4 attempt it opens a couple of feet...
If you release the garage door manual does it move smoothly up and down or is there some resistance if so your rails my need cleaning or spray oil or the rollers my need replaced if ok then check your chain on the track is to loose and needs adjustment
Mar 24, 2015 | Building Materials
Craftsman 1/2 hp garage opener opens and closes, but when it is finished closing the opener buzzes. When I put the door up the buzzing stops. The light has not worked for several years. I replaced
For the lights, very common the contacts get flattened out and melted. I see this every day. Unplug the opener and let it sit for about 30 min. I never wait but just to be safe, let the capacitor loose its charge. With a precision flathead screwdriver or fingernail, bend the contacts in the light socket out about 1/8". Should help. Buzzing concerns me a little. May be an electrical issue. These openers use an AC brushed motor. They get very hot and in rare cases can catch fire. Theres gear grease and dust inside that has ignited in a few motors. There is an overheat switch built in but dont count on it. I would suggest buying a new machine. Find a DC motor with a belt drive. They last the longest and require the least maintenance. Marantec make the best in my opinion.
Aug 30, 2014 | Craftsman 1/2 HP CHain Drive Garage Door...
I had a lightening strike at my home. Since then, the garage door does not function with wall switch or remotes. when i press the switch, light comes ON on the door opener and i hear a click but nothing...
Well, I don't think that disconnecting the garage door from the garage door opener would affect function.
The lightning strike could have destroyed the circuitry inside the garage door opener, seeing that it won't operate with the wall switch or remotes.
It's likely that a board was fried by the lightning which would render the garage door inoperable.
Aug 08, 2010 | liftmaster Chamberlain Garage Door Opener...
My garage door opener (liftmaster 1265) buzzes when attempting to open or close the door but the chain doesn't move
Remove the cover from the motor unit and check the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Apr 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener want work
Check to see if the traveler is against the bolt on the rail.
If it is, you need to loosen the chain and adjust the up limit to keep it from reaching the bolt.
Nov 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door
Disconnect the door from the opener and manually lift to see if it is binding.
Jan 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
886 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
