Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
The Air Compressor Smokes and Then turns off after a while.
I turn on my air Compressor and it works fine, but it smokes a lot, it looks like as if it was burning. And then, after a while of working it turns off by itself. What can I do to fix this?
  • juanloredo2 Jun 01, 2009
    Like the end, like the muffler part is where the smoke comes from.
  • John Moore May 11, 2010
    Which part seem to be smoking, the motor end or the compressor end.
  • 142 Answers
Sounds like the piston rings are blowing by allowing oil to get into the compression cylinder.
You should chuck it and go buy a new compressor as this one is more to fix than to replace.
Posted on Jun 01, 2009
I have a 2000 mazda 626 and my air conditioning is not getting cold. The freon is full in the car.the car smokes at a red light when just sitting there while air is on. Wht could be the problem?
Is it possible that the clutch on the compressor is not engaging or the compressor itself is locked up. When you turn on the air, does the engine bog down noticeably? If so one of the two above are likely.
Jun 06, 2015 | 2000 Mazda 626
2004 Chrysler Voyager, had an acrid burning smell and a lot of smoke when heater is turned on, also a rattling/squealing noise, all stops when heater turned off?
you more than likely have a sciezed air con compressor. most modern cars have climate control which uses air con even when demisting and when engaged the electric clutch tries to engage but the pump itself will not turn, clutch will get red hot and burn your belts
Nov 25, 2013 | 2004 Chrysler Voyager
My 92 tempo gl smokes like crazy when i first start it and some times runs rouhg for the first mile then clears up and then drives fine???
The valve stem seals are probably shot, if it is blue smoke-oil burning. What happens is when you shut the car off, oil slips down past the bad seals and pools around the valve seat. Soon as car is started, that pooled oil goes into the cylinder. When you shut the engine off, oil under the valve cover will do the same thing again-it will pool around the valves because of the bad stem seals. A repair manual can tell you how to replace the seals without pulling the head off. An air compressor is necessary to keep pressure in the cylinder, so the valve won't fall down into the cylinder.
Feb 21, 2013 | 1992 Ford Tempo
Turn on wont ignite if does smokes take top coveroff works fine
Must be starving for air then, check and make sure it is clean and unobstructed and air can get in around the finns to the flame. Is the blower fan running? I assume so if it lights.
Mar 15, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I have CraftsmanLT1000 lawn tractor, Smokes heavily.
Many times a dirty air filter will cause this on this style of engine. When the filter is plugged, it creates a 'rich' fuel condition, and the engine smokes heavily, the excess carbon is drawn into the air filter, and plugs it even more.
check spark plugs, air filter, fuel filter, choke linkages (for full choke/no choke operation) and crankcase oil.
Crankcase oil can become fuel contaminated, thus overfilling the crankcase and filling the crankcase breather with raw oil/fuel, and this is drawn into the air filter, plugging it, and starting this senerio.
If there is fuel in the crankcase oil, drain completely, and refill with fresh oil. Then you need to look towards the carb for an inlet needle sticking, broken, worn.
Nov 15, 2009 | Craftsman Garden
My 93 gmc vandura smokes from exaust when engine starts
You're burning oil, I've got the same problem with mine. It's not that big of a problem, just change the oil on time, mine has been doing it for years and there has never been a problem as a result.
Aug 03, 2008 | GMC V2500 Cars & Trucks
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
138 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
