Question about Sony Handycam DCR-PC109 Mini DV Digital Camcorder
Display is dark
The display on my Sony Handycam DCR-PC109 is dark. Its not on nightshot or supernightshot, and its not on backlight. The viewfinder works correctly, and it records normally. Its just that I can barely see on the display what I am recording outside, and inside - forget it.
Is there a factory reset? This might solve the problem since its otherwise working fine.
I checked the manual (on Sony's website), and couldn't find a solution.
TIA
  • 643 Answers
No reset. if you think you can open it reseat all the ribbon cables going to the Lcd.
Posted on Jun 01, 2009
Sony Handycam DCR-PC109 NTSC minicam--"Reinsert
The C31 indicates that there is a motor movement problem. I don't have the manual handy at the moment, but the :23 will indicate which movement is having the problem. This is not typically a DIY repair. I woul d strongly suggest that you check the fixed repair cost from a Sony authorized service center. This will not only repair the unit, but also reset it back to factory specifications.
I'll look up the error code tonight and try to update this.
Dan
May 26, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
Transferring digital video from dcr-pc109 to gateway laptop with only usb ports
If u have sony handycam then u got data cable for transferring data.
Use it for that u donot need any type of drivers for using that.
Otherwise use memory card reader if it is.
Aug 23, 2008 | Sony Handycam DCR-PC109 Mini DV Digital...
Can not set the camcorder to Super Nightshot Plus mode
To enable " Super Night Shot " option, find slide switch at top of camera as shown in picture...Regards,
Aug 21, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Batteries sony
Check the battery contacts on your recorder and look for any corrosion or oxidation.
Jul 26, 2008 | Sony Handycam DCR-PC109 Mini DV Digital...
Sony DCR-HC51
This is the solution, I would only add that it's on the top of the camera itself. Not in the digital menu or backlight button. On my older version, it's between the cassette and lens sections of the camera.
Never having used the nightshot before, my sister left me with the same quandary...
Jun 29, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony dcr-pc109
the battery wil not hold charge i replace it and same thing is happening help.
May 07, 2008 | Sony Handycam DCR-PC109 Mini DV Digital...
Sony Handycam DCR-PC109E User manual
I moved every moveable object on the handycam to no avail and then I wiped the screen to clean it and got the menu. It is a touch screen cam. Thanks antway.Ian
Feb 15, 2008 | Sony Handycam DCR-PC109 Mini DV Digital...
Cant see picture in viewfinder or on screen
Sony handycam dce-dvd 300. I can see the display and set up options but have a black screen otherwise.
Dec 15, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Handycam DCR-PC109 Mini DV Digital Camcorder Logo
224 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
