Question about Sanyo DS31590 31" TV
Sanyo ds31590 picture's very dark and red
Sanyo model # ds31590 was watching tv the other day, and out of the blue........ the picture went very dark and mostly red. there is some blue, but no greens.... have messed with all the color, sharpness, brightness, nothing seems to work. i am quite mechanical, is this something that can be fixed? and any ideas what part it could be and where can i find one?
  • 170 Answers
Re: sanyo ds31590 picture's very dark and red
Sounds to me that your picture tube needs rejuvenated.
You will need to get it done by a tech.
mechanical doesn't mean a thing when it comes to electronics.
Mechanics when working on electronics, end up costing more damage when you end up taking it to a tech.
Posted on Mar 04, 2008
0 characters
3 Points
Tv off!
A lot of these sets have a problem where a "filter cap" on the board in the power supply opens---Usually location is "C925 or C926" and it will be a 1000 mfd @ 25 or 35 volts.
Let me know if you can locate it--if so---unsolder the two leads (one marked with a plus and the other with a minus--positive and negative) and replace it----$4.00 part.
Jul 28, 2010 | Sanyo DS31590 31" TV
No picture, no sound.
contact sanyo, sounds like your display panel has gone bad
Sep 08, 2009 | Sanyo DS31590 31" TV
My sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
Jun 30, 2009 | Sanyo DS31590 31" TV
Sanyo 31'' Standard Def CRT TV
This is a vertical problem that can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages present inside hte set even when unplugged. If you wish to attempt this repair, please update this and confirm your model number as DS31590 and I'll supply additional details and instructions.
Feb 24, 2009 | Sanyo DS31590 31" TV
Tv won't turn on
Have you checked all of the cords? something might be unplugged.
Jan 22, 2009 | Sanyo DS31590 31" TV
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Nov 21, 2008 | Sanyo DS31590 31" TV
Very dark picture on TV
Try restoring all factory settings. On your remote, press the reset button twice. If that doesn't correct it, then you'll probably need a repair technician. For more info, consult your owners manual, which is also available at
Jul 27, 2008 | Sanyo DS31590 31" TV
Tv has no picture, has sound
this is a job for experienced tech need troubleshoot high voltage to picture tube 25 to 30 thousand volts
Mar 27, 2008 | Sanyo DS31590 31" TV
Sanyo T.V.
take the back off the tv and where the power cord hooks into the tv check the fuse there on the board if this isnt blown then you are probably looking at a power supply problem look at the board for anything that looks black and burnt or dark brown spots on the board. this will tell you where the problem is if it has any. but it just might be the fuse.
Dec 22, 2007 | Sanyo DS31590 31" TV
Sanyo DS31590 31" TV Logo
186 people viewed this question
Top Sanyo Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Sanyo Standard (CRT) Television Expert? Answer questions, earn points and help others
