Question about Kenmore Washing Machines
Wont drain tank
Pump just chatters wont empty tank
  • Kenmore Master
  • 2,005 Answers
There is an obstruction in the pump
obtain some radiator hose pinch-off pliers from an autoparts store
pinch off the top hose of the pump; lock the pliers closed (this will keep the water in the machine) then remove the pump cover and, repair
Posted on Jun 01, 2009
  • 6,784 Answers
HI, this is a sure bet that the impeller in the pump housing is damaged. that sound you are hearing is the impeller. the drive shaft has stripped the impeller. You will need to replace this damaged pump asap if possible.
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
My fisher & pay keel washer wa37t26gw2 won't drain, I have already tried taking off the drain pump checking it and making sure all hoses clear. When I tried to start a load after draining by removing...
Fisher/Paykels are notorious for bad drain pumps. If you hear any kind of squeeling, grinding, chattering, or such while it is drying to drain, you have a bad pump. P/N 479595
https://secure.fisherpaykel.com/us/Catalog/ItemContent.aspx?ItemNumber=268462&CatalogId=1&CatalogDetailId=35&NSM=Y
If while trying to drain, the water is emptying back into the washer tank, you have a bad or clogged diverter valve. p/n 426862P
Apr 07, 2014 | Washing Machines
2001 crystler town & country fuel pump
The Fuel pump is in the tank. The only thing I disagree with in emissionwiz post is whether to drain the tank or not. Chrysler started putting drains on the tanks in 2000 to make this easier when they went to a plastic fuel tank. I would drain the tank from the drain, disconnect the wiring then drop the tank to replace the pump. This all assumes that you verified that the fuse in the interior panel is not blown and the fuel pump relay in the power distribution box under the hood is still good.
Oct 25, 2011 | 2001 Chrysler Town & Country
AEG 73630: wont take water in, cant pump water out, when choosing a program the timer seems to have changed minutes with seconds, and when choosing af program, the only thing happening is, af few spins...
The machine knows what the water level should be at every step of the program, so if its full when it should be empty, is not filling when it should be or is taking too long to fill or empty the program will abort and count down in seconds as you describe.
First - check the drain filter for blockage!! if clear, can you hear the drain pump running on 'drain' program? a chug chug chug noise. If not pump may be jammed or seized - or the drain tube maybe be blocked at the waste connection on the sink, etc. Or maybe the water supply pipes have blocked or got turned off? Possibly the waste pipe may not have been installed correctly and the machine is syphoning empty? ie the end of the waste pipe is lower than the water level in the machine - so it syphons empty like draining petrol from a petrol tank! That would empty the machine when it should be full.
Check all the basics of filling, draining and filter before suspecting anything else.
Feb 01, 2018 | AEG Washing Machines
I accidently put diesel in my John Deere riding lawn mower. How do I safely drain the tank. Or do I need to take the tank completely off? If so I need directions.
If you did not try to start it, you will need to siphon, pump or **** out the fuel tank. The last J.D. that I emptied the tank in I used a turkey baster to draw out the bad fuel. I guess you use what you got. Hopefully your fuel is pumped to the engine and the fuel line goes into the tank from the top. If so all you have to do is empty and replace with gas. If the fuel line drains the tank from the bottom and/or you tried to start it with diesel in it you will need to (after emptying the tank) remove the fuel line from the carb. and direct it to a container, remove the bowl nut of the carb. to drain carb. be ready to clean up a little spilt fuel catch if you can or have rags under and ready. Turn the ignition key for engine to turn over to operate the fuel pump and clear the line. Put a little gas in tank and flush fuel line by using fuel pump to clear. Change fuel filter and put everything back together. Remove and clean/replace spark plug. Test it. Inspect spark plug again if necessary.
Jul 07, 2011 | Garden
Wont switch tanks
Try cleaning your fuel lines, fuel pumps if seperated at the tank, and fuel filters. If you have ever run out of gas in either tank, sediment from the bottom could have clogged the lines. Pump float might be stuck on an inner cavity or drain line inside tank. It may be switching, but if the float is stuck on something inside the tank, it will say it is empty when it is full. Tell me if this helps. I have recently replaced the entire fuel sys in my vehicle.
Nov 16, 2010 | 1987 Ford F 350
Log splitter how to flush hydraulic system
removing hydraulic oil from the system
  • fully extend the cylinder. and shutdown.
  • remove the one end of the hose that is from the rod end of the clylinder.
  • two ways you can go here. either: detach the one end of the hose that is attached to directional control valve and leads to the cap end of the cylinder and place the end in a pale then retract the cylinder by physically forcing the rod back in and all the oil will drain out of the cap end into the pale and the rod end will fill with air.
  • or u could hold the directional valve in the position to let the oil flow back to tank while physically forcing the rod back in. the oil in the cap end will drain to tank and rod end will fill with air.
  • drain the tank of oil.
  • if you wanted to be extra thurough remove the remaining lines and drain the oil out of them.
  • reattach all lines.
  • replace oil filters/strainers. should be one on the return line going to tank. and one on the suction line before the pump. But there may not be a second filter.
  • fill tank with new oil.
  • extend the cylinder using the pump. allowing the air to bleed off the rod side. may chatter at bit while extending. if excessive chatter remove line end to allow the air in the rod side to bleed to atmosphere and continue till fully extended.
  • reattach line. probably a good idea to run a couple cycles.
  • and repeat the entire process for a thurogh flushing.
  • ! note: dont be dissconnecting lines with pressure in them or while the system is running.
  • ! note: be sure to have enough oil in the tank so the pump is not sucking air. this will eventually cause unrepairable damage to pump if sucking air for too long.
  • i just wrote this off the top of my head and ive only worked on industrial hyraulic systems and never on a log splitter before so just keep that in mind. hope it helps
Dec 04, 2009 | Plumbing
Where is the fuel pump on a 2000 taurus
inside the gas tank. you will have to remove the tank to gain access to it. Some of the tanks have a drain valve on the bottom. If you do have the drain valve, it would be easier to drain the fuel before removng the tank unless it is near empty already.
If you are unsure your pump is bad, have someone turn on the key and listen by the tank for a short 1 -2 second humming sound. If you hear the sound your pump is working, if nothing check your fuses first otherwise the pump is bad.
Oct 13, 2009 | 2000 Ford Taurus
2002 miata
Only way to completely empty tank is to remove it. there is about a two gallon space between the pump and tank bottom where condensation can build up. You can partially drain it by disconnecting the fuel line and turning the key on. The pump will empty tank (don't run the pump after fuel is mostly empty or it will burn out) Also make sure that hose is secure so that fuel dosen't end up on the ground. After you have finished, put the battery on a charger and bring it back to best charge...Alternator will not and cannot do that.
Jun 26, 2009 | 2002 Mazda Miata
I was driving for about 15 minutes then i looked at my gas gauge and thought it was empty. It was below empty. My car shut off. Well...we put gas in it and it still wont start.. what could it be??
how much gas you put in?
if its below empty u would have drained the pump out you have to atleast have half a tank now and keep winding engine till the gas goes up the tubes again the tank and the tubes will be dry as a bone
Sep 14, 2008 | Chevrolet Beretta Cars & Trucks
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
