Question about Kenmore 73952 Gas Dryer
Kenmore gas dryer
It will run if you hold the start button but when you let off it should keep running but it just stops.
  • Kenmore Master
  • 8,220 Answers
Either a broken belt or a bad start winding on the motor.
Posted on Jun 01, 2009
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
I have a gas Kenmore Elite Dryer . When I turn it on and hit the start button it runs only if i hold the button in when i let it go it stops and the timer keeps ticking. Is it the igniter?
the most common problem with gas appliances not running is the flame probe. This device detects a flameout and shuts the gas valve. It could be faulty or not sitting in the flame itself
Oct 06, 2010 | Kenmore 63942 Dryer
Dryer does not stay on once I leave the start button off. Got to hold the start button to keep it running.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Kenmore 73952 Gas Dryer
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
Jun 11, 2009 | Kenmore 74992 Gas Dryer
Gas dryer - bruner will not come on
Probably a broken belt or a bad start winding. Remove the rear panel and check the fuse mounted on the blower housing. If open replace it and clear the vent to the outside. Click here for fuse locations and pictures.
Jun 01, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
psrao, right next to the timer under the consol is the even heat board. When this fails, it will cause this problem. This has been an issue with this model. Part number for the board is 3978949. Catriver..post back.
Jan 14, 2007 | Kenmore 73952 Gas Dryer
Kenmore 73952 Gas Dryer Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
