Question about Asrock P4I45GV R5 Motherboard
My video connection does not work monitor says "no signal." I checked all connetions and they's properly connected.
"no signal" message on monitor
  • cruzhumes Jun 01, 2009
    I installed pc 2700 256K RAM but it still does not work. I also tried installing a video card,but it still does not work.
  • Marcos Anguiano
    Marcos Anguiano May 11, 2010
    are you using the onboard video or an aftermarket video card
  • 85 Answers
Ok im assuming you have aftermarket video card... unplug the power and remove the video card and leave the RAM in place. Now reboot without a video card installed or monitor connected to anything. Do you get lots of beeps? If you do then reinstall the video card and make sure it seats well or you will get a no signal. Also make sure if its aftermarket that you do or do not need to plug a power connection to the card. Lots of the new card require you to plug a new 6pin power to it. Plz post your motherboard model and video card model if your using a purchased card. But just for assurance the error your getting is definately a video card issue and most of time its not seated correctly. :)
PLZ rate this TY
Posted on Jun 01, 2009
    Guru:
  • 597 Answers
Check to make sure you have correct ram installed in motherboard as the video card may share that ram. Check CPU that it's installed correctly and video should work. If not then the motherboard is bad.
  • obwhon Jun 01, 2009
    You didn't give me a lot of information to go on either. I am assuming that the system fired, fans ran, hard drive was spinning, the monitor was good, etc.I assumed that the video card was built into the motherboard. But that doesn't matter if you installed a seperate video card and it didn't work. You haven't told me what kind of motherboard or model it is but If it has a PCIE or AGP video slot and you put a matching video card in that was working and still got no result then I'd say the motherboard is bad.
I built my first PC, it powers on and everything seems to be working fine in terms of hardware. I connected the monitor and turned it on and it says no signal what do I do?
with computer power unplugged
pull video card out, then plug in check all connetions between monitor unplug and re plug in just to make sure their properly seated. if video card needed extra power connection check for that, check motherboard power connectors are firmly connected
just recheck your work
Jul 12, 2015 | Computers & Internet
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
No signal detected message on monitor, cpu and monitor are on
Good Day Jboone563!
You need to check if the VGA cable is properly fix to the monitor and video card. Loosen connection or no contacts is the reason for the "no signal" display on your monitor.
This means that there is no signal coming out from the video card, going in to your monitor. If by fixing the VGA connection did not fix it, try removing the video card from the motherboard and then reseat it properly to the motherboard slot.
If this do not resolve the problem, Jboone563, I'm sorry but you will need to replace the video card.
May 26, 2011 | AOpen 19" LCD
Power saving mode way ride this
An incompatible graphics card or operating system can cause this message to be diplayed. Check the vga cable connection on both the computer and the monitor. Make sure that the video card is working properly, check to see if there are any updated drivers for your vidoe card, make sure the video card is seated properly, if the card is not part of the system board.
You can then try the monitor on another computer if possible, you can even use a laptop to connect the monitor. You can also try another vga cable if you have one, cables do go bad once in a while.
This message generally shows when the monitor has a problem with the video signal being sent to it.
Let me know if there is any additional detail about this issue that I can know to be as helpful to you as possible.
Brian
Jan 08, 2011 | LG E1940S 19" LCD Monitor
Goes black with no reason
First check lcd connection is properly conneted to cpu. When connection is properly then open your cpu box and clean your ram and also where ram is put. Then rebot your system again it will work. When it will not work please change your ram.
Nov 06, 2010 | ASUS MW221C 22" LCD Monitor
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
May 21, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Lcd montor not working help
Symptom : No images on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power cord connecte properly.
Action : Check the power cord connection and supply.
Checklist 2 : Can you see "Check Signal Cable" on the screen ?
Action : (Connected using the D-sub cable)
Checklist 3 : If the power is on, reboot the computer to see the initial screen (login screen), which can be seen.
Action : If the initial screen( the login screen) appears, boot the computer in the applicable mode (the safe mode for Windows ME/XP?2000) and then change the frequency of the video card.
Note : If the initial screen does not appear, contact the Service Center or your dealer.
Checklist 4 : Can you see "Not OPtimum Mode", "Recommended Mode 1440 X 900 60 Hz" on the screen.
Action : You can see this message when the signal from the video card exceeds the maximum resolution and frequency that the monitor can handle properly.
Adjust the maximum resolution and frequency that the monitor can handle properly.
Checklist 5 : There is no image on the screen. Is the power indicator on the monitor blinking at 1 second intervals ?
Action : The monitor is in Powersafe mode.
Press a key on the keyboard activate the monitor and restore the image on the screen.
If there is still no image on the screen, press the On button. Then press any key on the keyboard again to activate the monitor and restore the image on the screen.
Hope this helps.
Have a good day.
Dec 08, 2009 | Samsung SyncMaster 920NW Monitor
Whenever i turn on my pc it says no input signal.i dont know whats wrong with it.is it the motherboard or the hard drive?
When you power up the cpu check your smps is working?
Then check num lock key on key bord if it is on and off when you press numlock then your cpu gives dispaly to monitor ok.
but if it not constant on or off no change when you press num lock key then you have to open cpu cabinet.
Refix RAM memory .
Clean dust from motherbord chipset.
Pull out cmos cell for 15 minutes so bios settings are reset to defaults.
then check.
refix all connection to mothebord like ATX power supply from smps.
Jul 23, 2009 | HP Pavilion a1540n PC Desktop
NO SIGNAL INPUT - message
Hi Rick,
Most common cause of this error is when the video signal cables are knocked off rendering the connection from the monitor to the CPU loose. Turn off the PC and secure all connections. Have you had your computer moved or repaired where you need to remove connections? Some PCs have more than one video cards (video output) and you may have connected it in the wrong video port. You can isolate the problem further by connecting your CPU to a known working monitor (office, freind's, neighbor, 2nd home PC). The other way is to isolate the problem is to connect your problematic monitor to a known working PC and see if video will be displayed. If video is present, your CPU's video card has gone bad or the contacts are not seated properly in the slot. Best Regards
Mar 27, 2008 | Gateway FPD2275W LCD Monitor
Asrock P4I45GV R5 Motherboard Logo
325 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
