Question about Bosch Washing Machines
I want to replace the door seal
My cloth washer leaks out the door.. front load unit
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch front loader washing machine
Posted on Jul 22, 2013
    Sniper:
  • 120 Answers
If you take the front panel of the machine off you will be able to replace the seal.
Posted on Jun 02, 2009
Ways leak from the bottom when you start the wash
this may be something stuck in the gasket(rubber) that seals the door. Fold down the gasket all thew way around the gasket, remove any thing hat may be there. This could be coins, small articles of clothing, or a wash cloth.
If no obstruction is found, it probrbly require replacement of the door gasket/seal.
Mar 27, 2011 | Kenmore Elite 45986 Front Load Washer
Clothing jammed front of washer and pulled front apron/seal away which caused water to leak out front. Fixed the seal and turn the washer on. The water turns on to fill the basket but now the motor will...
have you tried unplugging unit for a couple of minutes to reset? if so it is possible the motor control got wet and this could be the culprit. there are also some wiring around the front of unit are we positive nothing got disconnected... let me know
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Jan 08, 2010 | LG WM2487H Front Load Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
Clothes have holes from getting caught in seall during spin cycle
YOUR OVERLOADING UNIT,,CLOTHES SHOULD ,,FLOP LOSELY..TAKE A LOOK A THAT DOOR BELLOWS AND MAKE SURE ITS NOT WARPPED ,,PITCHING TO FAR TO THE INSIDE OF UNIT,,ONTHEJOB..
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer Leaking
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process of how to fit and replace
Sep 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
132 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
