Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub cadet 2160 PTO problem
On my 2160 the pto will not engage, no clic when the mower is off and the switch is turned on. no power at the connector going to the pto. Problem began intermeittently, used to just hit the forward and reverse a couple of times and it would come back. is there a sfety switch attached to the forward/ reverse that can go bad I can't seem to find away into that area on the right side of the tractor above where the reverse swith is located. Or could it just be a bad PTO switch.
How do you disconnect the reverse safety switch on a cub cadet 2160... where is it located?
Posted on May 30, 2011
2 Suggested Answers
  • 109 Answers
SOURCE: cub cadet 2160 PTO problem
Yes, there is a switch on the motion lever on the transmission, but there is also a relay switch that is taped to the fuse under the hood of the mower...if this goes bad, the deck will not come on
Posted on Jun 03, 2009
The lever to engage the blades on my Cub Cadet rider LTX 1042 KW has no resistance the the blades do not engage. Did a part possibly break off or come loose?
The blades are engaged electrically via the PTO on the engine shaft.
Check the connector and wiring to the PTO unit, or the electrical plug on the engage switch.
Oct 09, 2016 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
Ihavert42.zero turn pto will not work
Check PTO switch
check fuses
check safety switches on the mower.
Mid all good then you will probably need to replace the PTO clutch.
Check switches using a voltmeter
Jul 11, 2015 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
After reverse, my cub cadet zero turn mower pto will not re engage the blades. sporadic up to the point of stopping altogether. is it the switch or clutch?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
Aug 10, 2014 | Cub Cadet Garden
1806 cub cadet PTO blows fuse when engaged
check the pto switch..un hook it if thats it then replace
Nov 19, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Jun 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,329 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
