Question about Sony KDF-E60A20 60 in. LCD HDTV
Dusted the bulb box. then when i turnd tv on, picture is unstable
The picture became two... and also moving left and right like a shaky motion...
    Problem Solver:
  • 5 Answers
Make sure you put everyting back correctly. It can be that you forgot to tighten the allen bolt and the cage is moving.
Posted on Aug 31, 2009
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
How do I get in there safely to clean the mirror?? what do i unscrew first etc.. it still working just fine but the color is going after 15 years and i need to clean the inside.
Hello.
I would not recommend you to touch the mirror. It is hanged sort of reflection surface facing down so it is not real dust collector. You can clean lenses of your CRT tubes (red, green and blue) to improve your picture. Just remove rear cover taking out black and golden screws and you will see dusty lenses right away in the middle of the TV. Use DRY "Bounty" paper towels to remove dust from lenses, don't wet it with any solutions or it will leave film on optics. Just in circular motion move dust to the black plastic edges of lenses. Don't worry about some specs of dust that inevitable will be left behind - they will not affect image at all like thick layer of dust do.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi VS-6041 60" Rear Projection...
No sound, just like it is muted
samsung dlp tv hlp4667w still picture and white lines over picture with no sound, i turn it off and then on by unpluging the tv and it worked. the picture is shaky from right to left. there is no response from the remote or the main switch on tv when this happens.
Oct 18, 2009 | Samsung HL-P4667W 46" Rear Projection HDTV
Hair and particles on pictures-not on lens or mirror-on sensor
You must have dusty mirror box area. Here is what you should do. 1. Remove lens from the body. 2. Blow out any dust from the mirror box area using can duster (careful not to spew out liquid). 3. go to menu and select mirror up or ccd clean mode. You can also set at manual shutter speed "B" and hold up the mirror. 4. Blow out dusts over the CCD sensor (Do Not Use can air! If any liquid sprayed on CCD the cleaning gets worse) so use Hand-squeezee air bulb. You can purchase one from any camera stores.) 5. test shots and repeat. 6. If this procedure did not resolve the removal of the dust, you can purchase a cleaning solution package and try it. I do not recommend it becasue our techs get lots of cleaning requests from these package. Remember, if you are using these solution, 1. Never give any pressure to the screen, just tissuie touch pressure only. 2. move circular motion as you mouth blow the air as you move. complete the motion exiting through the corner of the screen. Did not work? send it to repair techinician! Our tech cleans it for $49. 24 hour turn around and also checks the camera too. Good Luck
Mar 26, 2009 | Nikon D70s Digital Camera
Shaky picture AKAI PDP4298ED1
THERE MAY BE SOME CONDENCER LEKAGE SOMEWHERE IN THE HORIZONTAL SECTION
Mar 23, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Shaky/Unstable Picture
This is power supply issue, one or more of your filter capacitors either bursted and/Or over heats (this is why it becomes better when system cools down after turning it off for 1/2 hour..You have two choices.1. buy a replacement power supply may set you back a couple hundred dollars but it will be plug and play. 2nd you can replace these filter capacitors make sure the can handle 105 deg celsius not the 85 deg. celsius, if you know how to trace the bad ones and desolder and solder new ones on the power supply board, or hire a techinician to replace them for you. Good Luck...
Dec 14, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Picture on email is unstable looks shaky.
if u have graphics card means jus remove it and connect it in the ordinary pin
Jul 03, 2008 | E-Machines eMachines Desktop PC
Shaky Picture only during Advertisement or... Mitsubishi SC 27403
If you have cable then put the cable wire directly in the TV, bypassing the cable box. If the pix is Ok it proves that the problem is the cable box. If the problem is still there then it proves the the TV needs parts inside.
Mar 24, 2008 | Televison & Video
Sony TV KP-46WT500, 46" Rear Projection TV , colors mixed up
You have a pair of Bad STK392-560. replacing these will definitely fix the set.
Best regards
CircuitCity
Dec 19, 2007 | Sony KP-46WT500 46" Rear Projection...
Round shadows in picture
Sounds like the Bulb is almost out of life or a dustball or something is moving around inside the light compartment. Look in the instruction or user manual on replaceing bulb or opening bulb compartment or call Mits. for a service center in your area. Good Luck
Jun 24, 2006 | Mitsubishi WD-62525 62" Rear Projection...
Sony KDF-E60A20 60 in. LCD HDTV Logo
112 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
