Question about Toshiba 57H82 57" Rear Projection Television
Wavvy lines, wiggy
We have a 57H82 Toshiba set about 4.5 years old. Asking if it easy to take the metal box apart and does the new HYPERBOARD pop in. Easy to replace those 16v/10uf caps or best to buy the board. If so how much would the board cost?.
From good ol Vancouver, B.C. Canada
thanks
Doug.
  • jordangolfer Feb 03, 2009
    i have a similar problem with my toshiba 42hdx82 there seems to be a problem with the vertical pixels this is because when using touch focus i can see wavy lines in the vertical alignment bars
    is there any other solution other than opening up the tv and tampering with its harware
Dougers, I am next door, in Alberta. I have fixed my hyperboard by replacing the surface mount caps myself in my workshop for a fraction of the cost of a replacement board.
See my other thread for more information.
Posted on Oct 24, 2007
  • 87 Answers
The hyper board part #23148024 is NLA.  There are 2 solder tabs on each side of the board that have to be usoldered from the signal board and then the hyper board will unplug.  I do not recommend changing the capacitors as they are surface mount and it is very easy to damage the board beyond repair.  PTS electronics will repair the board for you but will not do so if the board has already been damaged.  I have one in stock.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
I have lines on my TV when it first turns on and when it warms up they go away. I think the projector lamp is going bad and was wonder if I could replace the lamp myself and which lamp would fit my Toshiba...
this is known as hyperboard or hypermodule problem. Now toshiba knows about this problem (common) and has issued repair instructions for service centers. The bad news is this repair is quite labor intesive. When this fault first occured the thing to do was to replace the cuircit board. as time went by the board became more difficult to find. So the discovered and intructed how to fix this board on the component level. The repair involves removeing the board. This board involves removing alot to get to it. Then replaceing 11 micro capacitors. Let me just say it takes very experience tech some time and a large magnifer with twezers a few hours to do this. i have repaired a few and i still have trouble. it is very easy to damage the board. IT CAN BE FIXED and labor cost might add up. our shop repaired about 2 of these of month for around 300 and most of that was labor if you choose not to fix it it might last 6 months or a year.
Feb 16, 2011 | Toshiba 57H82 57" Rear Projection...
My 57h82 picture has picture noise in form of small jagged/wavy lines at edge of objects - particularly noticable for text or numbers. This appears on all channels and with all input sources. How to fix?
Is a common problem. Your hyperboard has failed. You can get a repair kit from www.TvRepairKits.com or buy a used hyperboard - but it will also fail someday unless it has been repaired with better parts than what the factory supplied.
Dec 22, 2010 | Toshiba 57H82 57" Rear Projection...
We have a Toshiba HDTV model number 57H82. It is
Sounds like a bad tuner/decoder on the Qam analog side of things. You can bypass this with a Clear qam converter box or a analog to digital tuner box or simply having this repaired upwards of $200 bucks.
Thanks for using Fixya.com
You're Toshiba Tv Expert.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 picture goes black
Poor connections on power supply board .
Aug 06, 2009 | Toshiba Televison & Video
57H82 when I first turn on the tv it is all distorted looks kind of smeared and you can not make anything out. after about 15 to 20 min after it warms up you can see the picture but it has vertical wavey...
You can try setting the convergence for your tv which will be explained in the manual (if you don't have it anymore you could try the support page for Toshiba). I had a model like this, and when they get old you can get alot of dust inside which can affect the tv, and just years of use can sort of wear them out. I am a certified installer, and to get mine back to an old tv with a good picture was going to cost me $250 for the parts necessary. An electronic repair bill could be in the hundreds of dollars and you would still have an older tv. If you don't mind the slight inconvenience of waiting for it to warm up or the lines, that option doesn't cost any more money right now.
Aug 05, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 problems
Val,
It's sent via Pando and you should get a link to it in your mail. To open it you'll need Pando, it's a free download if you don't already have it... The hyper module on that has about 10 caps that are common in that failure. If you need anything off board don't hesitate to ask.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Jan 07, 2009 | Toshiba 57H82 57" Rear Projection...
Tosh 57h82 flashing led and bad hyper board.
For a service manual, contact Toshiba directly.
Jun 17, 2017 | Toshiba 57H82 57" Rear Projection...
Toshiba 50H82 hyperboard caps
Service manual won't help much in the hyper board and that's likely the problem.. Simply remove the hyper board and open the can. Inside you'll see a number of smd caps. There are 11 10mf/16v that need to be replaced...
Bill
Jul 26, 2008 | Toshiba 57H82 57" Rear Projection...
57h82
Heres your link for the capacitors http://www.mcminone.com/search.asp?keyword=surface+mount+capacitors&btnSubmit.x=8&btnSubmit.y=7&btnSubmit=GO Loads of info here about the board http://www.techlore.com/forum/thread/15237/Toshiba--Model4283--picture-is-zig-zag./ Good Luck
Jul 16, 2007 | Toshiba 57H82 57" Rear Projection...
Wavy picture on all sources
This is a somewhat common problem having to do with the hyper module, Toshiba p/n#23148024 There are a gouping of 16v/10uf caps in the hyper board that fail causing the distoritions you're describing here. At first, as the module begins to go bad the distoritions are present and usuallly go away or fade significantly as the set warms up - - this gets worse until the distoritions don't go away at all... From what you're saying you're at stage three already. :) You have a few of options: (1) local repair shop pull the board and replace the caps or module; (2) Pull the module yourself and repair or send it in for board level repair; or (3) pull the hyper baord, order a new one and put it in yourself. For 2 or 3 you'll be better off having the service manual and if you need it just email me privately and I'll send it. Make sure in your request to tell me the model number and reference something of this repair so I have a clue of what you need. BTW the hyper board is on the left side of the unit mounted vertical on the signal board inside a metal can. Good Luck Bill
Jun 10, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
187 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
