Question about Ryobi Garden
No power I have a ryobi 725r weed eater. I can get it to run, for about five sec. Run the throttle and gas just spits out the exhaust, It dies after the 5 sec run time, I tore apart the carburator and cleaned it up, still does the same thing. A little help please I have 705r Ryobi string trimmer with similar problem. Seems to have no power (does not increase rpm without stalling) and seems to be starved for fuel (only starts after being choked0) and sometimes only runs on partial choke (but still no power). I removed the carb and checked / cleaned internally as much as possible. the fuel system seems to be VERY clean, but that's only what I can see. I removed the red / white caps and adjusted both screws from zero to completely removed with no discernable change (except from zero to 1 turn which would not run at all). Is there something else to check besides the carb? All other screws are tight.
  • 284 Answers
Check for restricted exhaust next
some manufactuers put screens in their exhausts and they tend to plug up sometimes remove clean and put back screen.
When you removed carb. and dimantled were the rubber pieces soft and pliable? if they were not then consider a carb. kit
Be sure on the needle valve side of the carb. the diaphram side
the gasket goes first then the diaphram not the opposite. Zama or walbro the same deal
sometimes you have to dismantle the carb totally and drop it in carb. cleaner for awhile to allow to penetrate where its hard to clean and sometimes you have to replace the carb,but not always
the initial carb. setting for high and low is 1and1/4 turn and tweek from there.
Also the smallest pinhole in the fuel lines will create havoc also.
and if compression is weak or low the carb. will not work properly either.
Try these things and maybe it will help you some?
Posted on Jun 02, 2009
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Sparkplug gap for a 31cc ryobi weed eater
If its a 725r ryobi weed eater it takes a champion RDJ7Y with
a gap of 0.020 in. or (0.5mm) with a feeler gauge.
torque @ 110-120 in.lbs. good luck!
Jun 28, 2011 | Garden
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Rhobi weed eater stalling
Try spraying some carb cleaner into the intake while its running - with the air filter out..
If that doesnt help & if it sat for a long time without being run - you might need to get the carb reuilt..
Hope this elps !!
rate me good ;o)
Jul 14, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My weed eater will start but when I push on throttle it dies
well take the spark plug out take some WD40 and give it a shot inside the unit, remember to keep the unit level when hitting the throttle and allowing it to warm up for a few minutes before use also make sure where your choke lever is. also when starting I start it on the ground like most manuals state and leave it idle on the ground for a minute before picking it up and then when I pick it up I make sure that the gas tank is tilted towards the ground so there is no room for air to get into the filter causing and disturbance while the unit is warming up.
Nov 15, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
494 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
